Bunsen Coefficient Solubility Calculation Units?
In summary, the conversation is discussing an equation for calculating dissolved gas concentrations in water at varying temperature and salinities. The equation includes coefficients that are specific to different gases and assumes a constant pressure. It is possible to use Henry's Law to determine the concentration of gases at various partial pressures, but it may not account for the effect of salinity. The conversation also touches on the idea of linear scaling with pressure, which is equivalent to Henry's Law.
jeanius
I've been reading about calculating dissolved gas concentrations in water at varying temperature and salinities using an equation of the form:
ln(β)=exp(A1 + A2*(T/100) + A3*ln(T/100) + A4*(T/100) + S*(B1 + B2*(T/100) + B3*(T/100)^2
where β is in units of mL/L, and A# and B# are empirically derived least square fit constants, different for specifics gases. My question is how to relate mL/L solubility to mg/L or mol/L of the specific gas in solution, say of oxygen in water. Any help would be appreciated! Thanks!
Chemistry news on Phys.org
Coefficients are given for a specific pressure - you know P, T & V, use ideal gas equation.
So I would determine the volume of gas present by multiplying my sample volume by beta to get mL of gas, convert to m^3 for V, and use the partial pressure of oxygen for P? Or rather the pressure of the environment?
Why partial pressure? You are calculating volume of pure gas dissolved.
Whether you will convert volume to L or m3 is a secondary thing, you can always choose such an R value that will incorporate any volume units you need.
But say it was a gas mixture or oxygen, nitrogen, argon, hydrogen, etc. all at different partial pressures, would I use partial pressures then?
Equation gives you answer in terms of pure gas, so no, no partial pressures.
Would I use dalton's law at that point? Or would I calculate the average molar mass for R_specific, then determine each gas' moles from their respective partial pressures?
Actually I am no longer sure.
Equation doesn't contain any pressure related expressions, so it most likely assumes constant pressure - and what pressure is assumed should be given together with coefficients, otherwise they are useless. If the answer calculated is given as mL per L, it would be logical to assume it is mL of the PURE gas dissolved in L of the water. That in turn means you don't need Dalton's law, partial pressures, averaged molar masses - you do calculations for each gas separately, assuming its pressure is that for which coefficients are given.
Could be coefficients are given assuming solution in equilibrium with atmosphere - in such a case you will have to use partial pressures of oxygen, nitrogen and argon (assuming some total pressure - again, probably atmospheric). But that's like scratching right ear with the left hand - clumsy and inconvenient, so it sounds highly unlikely.
Note: I doubt you will get correct results while trying to calculate concentrations for a mixture using equation you have listed - my bet is that it works OK for a solution containing one gas only, when there is more than one gas, their solubility are not independent.
I believe the equation should be valid for 760mmHg. If you go by Henry's Law, you'd be able to determine concentration of gases at various partial pressures no problem, but you'd be out a salinity term. Regardless, an actual pressure compensation isn't present in the equation, and I'm wondering how I'd go about accounting for that. If I'm given solubility of a gas at 760mmHg, regardless of how many gases are present, shouldn't I be able to scale that according to the partial pressure present in the environment? A mL of gas at 760 should scale linearly to a mL of that same game at a different pressure right?
Linear scaling with pressure sounds logical - that would be my approach.
This does sound right, though I can't back it up very solidly. Is there a way you know of that this couples to Henry's Law?
Linear scaling with pressure IS Henry's law. Equation you listed is not, as it doesn't say a word about pressure. The way the Bunsen coefficient is defined suggests it is an equivalent of proportionality constant from the Henry's law. This coefficient is always a function of temperature and solution composition (that is, presence of other solutes) and your formula takes it partially into account.
What is a Bunsen Coefficient?
A Bunsen Coefficient is a measure of the solubility of a substance in a particular solvent. It is named after the German chemist Robert Bunsen, who developed the concept in the 19th century.
How is the Bunsen Coefficient calculated?
The Bunsen Coefficient is calculated by dividing the concentration of the substance in the solvent by the maximum concentration of the substance that the solvent can hold at a given temperature. This is known as the saturation concentration. The result is a unitless value that represents the solubility of the substance in the solvent.
What are the units for Bunsen Coefficient solubility?
The units for Bunsen Coefficient solubility vary depending on the specific substance and solvent being used. However, they are typically represented as moles per liter (mol/L) or grams per liter (g/L).
How is the Bunsen Coefficient used in scientific research?
The Bunsen Coefficient is an important tool for understanding the solubility of substances in different solvents. It is often used in fields such as chemistry, pharmacology, and environmental science to determine the optimal conditions for dissolving a substance in a particular solvent. It can also be used to predict the behavior of a substance in different solvents.
Are there any limitations to using the Bunsen Coefficient?
While the Bunsen Coefficient is a useful tool, it does have some limitations. It assumes ideal conditions, such as constant temperature and pressure, and does not take into account factors such as the presence of other solutes or the rate of dissolution. Additionally, it may not accurately reflect the behavior of substances in non-aqueous solvents or at extreme temperatures.
  • Mechanics
  • Chemistry
38K
