Calc: Derivative of f(x)=3x2-7x+5 - Newbie Guide
In summary: Rather than trying to teach yourself using on-line sources, you would probably do better to read a book on the subject. Some people praise the Schaums Outlines books, but, really, most introductory books could be very helpful to you. There even several free ones available as PDF files; you can find them by doing a Google search for 'free calculus books'.
MarcAlexander
45
1) f(x)=3x2-7x+5
2) [itex]\frac{f(x+h)-f(x)}{h}[/itex]
What is the value of equation 2?
NOTE: I'm new to Calculus. I'm trying to self teach by using the internet.
Thanks in advance. ;)
MarcAlexander said:
1) f(x)=3x2-7x+5
Is equation 2 equal to -7?
No, it isn't. It will have x's and h's in the expression.
May I inquire what the answer is?
MarcAlexander said:
1) f(x)=3x2-7x+5
2) will contain both x and h. If you mean the LIMIT as h --> 0, then that would contain only x. Even so, its value would depend on what value of x you choose.
If you show us your work we can make more meaningful comments.
RGV
The answer is 6x-7 to help you, but show what you did so people can tell you what is wrong.
Would another form of 6x-7 be [PLAIN]http://www.myalgebra.com/math_image.aspx?p=3hxSMB02ESMB032SMB02eSMB03-21hx-18x-105?p=170?p=22?
That number is the result myalgebra.com calculated.
Obviously not: one expression has x alone, while the other has both x and h.
RGV
What is a derivative?
A derivative is a mathematical concept that represents the rate of change of a function at a specific point. It is often used to find the slope of a tangent line to a curve at a given point.
How do you find the derivative of a function?
To find the derivative of a function, you can use the power rule, product rule, quotient rule, or chain rule depending on the complexity of the function. In this case, we can use the power rule to find the derivative of f(x)=3x2-7x+5.
What is the power rule?
The power rule states that the derivative of a function with the form f(x)=xn is f'(x)=nxn-1. In other words, you can take the exponent of the variable and multiply it by the coefficient, then decrease the exponent by 1.
How do you apply the power rule to f(x)=3x2-7x+5?
Using the power rule, we can find the derivative of f(x) to be f'(x)=6x-7. This is because the exponent of x2 is 2, which we multiply by the coefficient 3 to get 6, and then decrease the exponent by 1 to get x1. The derivative of -7x is -7, and the derivative of a constant is 0.
Why is the derivative important?
The derivative is important because it allows us to analyze the behavior of a function at a specific point. It can help us determine the slope, concavity, and critical points of a function, which are important in many scientific and engineering applications.
