Discrete Random Variable - basic question in probability.
In summary, the expected value of a geometric distribution can be calculated using the moment generating function method or by using the geometric series formula. By taking the derivative of the geometric series, the expected value can be simplified to 1/p, where p is the probability of success. Alternatively, Riemann Sums can also be used to approximate the expected value.
Roni1985
201
If X is a discrete random variable having a probability mass function p(x), the expectation or the
expected value of X, denoted E[X], is defined to be
E[X]=Σ x*p(x)
A biased coin is tossed until “heads” appears for the first time. If the probability of a “head” for
the coin is 2
5 , the expected number of tosses needed to get “heads” for the first time is given b
Σ(n*2/5*(3/5)^(n-1)
the summation is from n=1 to infinite.
Compute the expected value. (the expected value need not be an integer.)
Σ(n*2/5*(3/5)^(n-1)=5/2
First I found the number of tosses needed to get heads, but I don't understand how to interpret this in the E[X] formula.
I know that my
p(x)=.40
what is my x ? "tails for the first time" ? how to translate it in a numerical representation ?
and the summation is from n=0 to n=2.5 ??
Thanks,
Roni.
Seems like a geometric distribution.
Let's define X = number of tosses needed until the first head appears.
When x=1, it means that you get a head in your very first toss. So, p(x=1) = 0.4
When x =2, it means that you get a tail in your first toss and a head in your second toss, so p(x=2) = (0.6)(0.4).
When x = 3, ..., p(x=3) = (0.6)^2 (0.4)
...until...
When x = n, ..., p (x=n) = (0.6)^(n-1) x (0.4)
So, your E(X) = summation of x times p(x) [values of x is from 1 to infinity]
= 1 x p(x=1) + 2 x p(x=2) + 3 x p(x=3) + ... + n x p(x=n)
=1x0.4 + 2 x (0.6)(0.4) + 3 x (0.6)^2 x (0.4) + ... + n x (0.6)^(n-1) x (0.4)
Factor out 0.4.
Now, either the E(X) is a value or it might not be convergent. If it's the latter, than E(X) does not exist.
Hope that helps. ;)
Okay, I find the formula for calculating E(X) for a geometric distribution.
E(X) = 1/p. (obtained by using the moment generating function)
So in this case the answer is simply E(X) = 1/0.4 = 2.5 ;)
Thank you for your help, it did help me understand.
I just forgot to mention one thing. We should use calculus in our answers.
I don't think we are supposed to use geometric distribution.
However, geometric series might work here.
I just don't know what to do with the 'n'.
the sum of a geometric series is
S=a/(1-r)
the 'r' is 3/5
but I can't figure out the 'a' since it's a constant number.
Thanks.
You're welcome. ;)
I am still not able to solve the problem with the geometric series formula (a/(1-r)).
Is it even possible ?
Thanks
up :)
I think you can use the moment generating function method to compute the sum. It's about differentiation and summation.
http://answers.yahoo.com/question/index?qid=20080121114534AAXsi9J
The mean is:
E(X) =
∑ x * P(X = x)
x = 0
∑ x * p * q ^ x
x = 0
change the index, the first terms of the sum is zero so we can start the index from 1
∑ x * p * q ^ (x - 1)
x = 1
factor out a p
p * ∑ x * q ^ (x - 1)
. . x = 1
note that the argument in the sum is a derivative:
∂ q^x / ∂q = x q ^ (x-1)
p * ∑ ∂[q ^ (x - 1)] / ∂q
. . x = 1
it is not a trivial task to interchange a sumation and differentiation but it is valid in this case.
p * ∂/∂q ∑ q ^ (x - 1)
. . . . . . x = 1
the sum is a geometric sum missing the first term and will evaluate to (1 / (1 - q) - 1)
p * ∂/∂q * (1 / (1 - q) - 1)
take the derivative
p * (1 / (1 - q)²)
write in terms of p
p * ( 1/ (1 - (1-p)² )) = p / p² = 1/p
qed.
You can substitute in the value of p = 0.4 into the working shown above. ;)
Thanks
Yes, it is possible. Your expectation for this particular X is
[tex]\sum_{n=1}^{\infty}n\left( \frac{2}{5} \right) \left( \frac{3}{5} \right)^{n-1}
= \frac{2}{5} \sum_{n=1}^{\infty}n \left( \frac{3}{5} \right)^{n-1}
[/tex]
The sumation is the derivative of the geometric power series [itex]\sum x^n[/itex] evaluated at 3/5. Since that series sums to 1/(1-x) then our series is 1/(1-x)2.
So
[tex]\frac{2}{5} \sum_{n=1}^{\infty}n \left( \frac{3}{5} \right)^{n-1}
=\frac{2}{5} \cdot \frac{1}{(1 - 3/5)^2} = \frac{2}{5} \cdot \frac{25}{4} = \frac{5}{2}
[/tex].
--Elucidus
[/tex]
So
[/tex].
--Elucidus
Thank you for your answer, you really helped me here.
I was wondering if it's possible to solve it with Riemann Sums ?
I know it's going to give me a good approximation.
Thanks.
[/tex]
So
[/tex].--Elucidus
Now that I am looking at your answer again... I don't think I understand how you are getting 1/(1-x)^2.
I understand that 1/(1-x) would be perfect here if we didn't have the 'n'
EDIT:
Now, that I am looking at it again, I noticed that it's the derivative of 1/(1-x).
Thanks.
What is a discrete random variable?
A discrete random variable is a type of random variable that can only take on a finite or countably infinite number of values, with each value having a specific probability of occurring.
What is the difference between discrete and continuous random variables?
The main difference between discrete and continuous random variables is that discrete random variables can only take on a finite or countably infinite number of values, while continuous random variables can take on any value within a certain range.
How is the probability distribution of a discrete random variable calculated?
The probability distribution of a discrete random variable can be calculated by determining the probability of each possible value occurring and then summing all of these probabilities. This distribution can then be represented in a table or graph.
What is the expected value of a discrete random variable?
The expected value of a discrete random variable is a measure of the central tendency of its values and is calculated by multiplying each possible value by its corresponding probability and then summing all of these values.
Can a discrete random variable have a probability of 0?
Yes, a discrete random variable can have a probability of 0 for certain values, meaning that these values have no chance of occurring in a given experiment or scenario.
