Time of flight of an accelerated electron in a television tube
In summary, the conversation discusses a problem given as homework involving a television tube with a distance of 0.3m from cathode to screen and electrons accelerated through 20 kV. The group discusses using the force due to an electric field and Newton's second law to calculate the time it takes for the electrons to travel to the screen. They also mention using the equation V = E*d to find the force and a website as a helpful resource for physics.
dranger35
I was given this problem for homework.
Assume you have a television tube that is about 0.3 m from cathode to screen, and electrons are accelerated uniformly through 20 kV – the electric field is constant. How long does it take for the electrons to travel from the cathode to the screen? The electron mass is 9.11x10-31 kg.Assume you have a television tube that is about 0.3 m from.
Can any1 let me know what equation to start off with adn one to find the time. Thanks
You should look at the force due to an electric field, F(vector)=q(scalar)*E(vector)
Now that you have the force due to the electric field, simply use Newton's second law to get the acceleration.
With the acceleration and the distance to the screen, you should be able to get the time of flight.
Yea but how do I know the F if I don't know q or E? Thanks again, I'm really confused with it.
In this case you may use:
V = E*d
Read your book sometime!
Yea that's the problem, there is no book for the class so we have to get it from our heads and the teacher for some reason is expecting us to know it.
1. How is time of flight of an accelerated electron in a television tube measured?
The time of flight of an accelerated electron in a television tube is typically measured using an oscilloscope, which detects the electron beam as it travels from the cathode to the anode. The time between when the electron is emitted from the cathode and when it reaches the anode is then calculated.
2. What factors can affect the time of flight of an accelerated electron in a television tube?
The time of flight of an accelerated electron in a television tube can be affected by the strength of the electric field, the distance between the cathode and anode, and the initial velocity of the electron.
3. How does the time of flight of an accelerated electron in a television tube impact the image on the screen?
The time of flight of an accelerated electron in a television tube determines the location of the electron beam when it strikes the screen, and therefore affects the position of the pixels on the screen. This ultimately impacts the clarity and sharpness of the image displayed on the screen.
4. What is the relationship between the time of flight of an accelerated electron in a television tube and the frame rate of a television?
The time of flight of an accelerated electron in a television tube is directly related to the frame rate of a television. The faster the electron beam can travel from the cathode to the anode, the higher the frame rate can be, resulting in smoother and more fluid motion on the screen.
5. Can the time of flight of an accelerated electron in a television tube be altered?
Yes, the time of flight of an accelerated electron in a television tube can be altered by adjusting the voltage of the electric field, the distance between the cathode and anode, and the initial velocity of the electron. These adjustments can be made to improve the image quality and performance of the television.
  • DIY Projects
10K
  • Electrical Engineering
