Calculate % Silicon in Silicate Mineral | Danne
  • Thread starter danne89
  • Tags
    Calculation
In summary: So the final answer is approximately 39.9%. In summary, the conversation discusses the calculation of the percentage of silicon in a silicate mineral, given the weight of silicon oxide obtained during analysis. The participants initially have different answers but eventually agree on the calculation method, with the final percentage calculated to be approximately 39.9%. The conversation also touches on the composition of silicate minerals and the molecular mass of silicon dioxide.
danne89
180
Hi!
How many per cent of silicon is there in a silicate mineral, if 0.567 g during analysis gave 0.484 silicon oxide.
Gratefull,
Danne
Chemistry news on Phys.org
danne,
We really can not help you unless you first make an attempt. What ideas do u have ?
Oh, I'm sorry. But I've not any cloue.
Okay.
[tex] percentage \ Si =\frac{m_{Si}}{m_{compound}}\cdot 100 [/tex]
Daniel.
Ask yourself : how much Si is there in SiO2 ?
Okej, I've: % Si = Si:Si02 * 100 = 2800:60 ~= 47%
So the weight information's only purpose is to trick you? :(
No,its purpose is to help answer the problem's question.Reread its text and see what it needs to be done.
Daniel.
(0.567 * Si * 100):(0.484 * Si02) = (56.7 * 28):(0.484 * 60) = 1588:29.04 ~= 55%
Sorry for the amount of numbers, I'm using log-table.
I'm sorry,u have no reason to applogize,even after coming up,again,with a wrong answer.
My answer is "roughly 40%".
Daniel.
danne89 said:
Hi!
Gratefull,
Danne
What's the unit of .484 ? grams?
dextercioby said:
No,MeV/c^{2}... :tongue:
Daniel.
alright... I don't get 40 % when i try this problem out.
SiO2 = total weight
SiO =.484 grams
O = Total weight - .484 + (weight of O inside Silicon oxide)
Well we know how much Oxygen is in there we can easily figure out the percentage of Si...
I don't get 40 %... I think you've mistaken SiO for SiO2 (silicon oxide not dioxide)
Of course it's [itex] SiO_{2} [/itex].
Daniel.
P.S.Does Silicium form oxides at +2??My guess is "no"...
% Si = (0.567 * Si * 100):(0.484 * Si*Si02) = (56.7 * 28):(0.484 * (28 + 28 + 2 * 16)) = 1587.6:(0.484 * 88) = 42.59%
Yes! At least my slow head isn't act as a fools mind.
Explain that part:
[tex] (28+28+2*16) [/tex]
Why on Earth did u add 28 TWICE?
Daniel.
P.S.Is it [tex] Si_{2}O_{2} [/tex] ??
I add the Si and Si02 together.
Edit: Which seems to be quite idiotic now...
Can I have some more hint?
Why would you do that for?It's only SiO_{2} in the mineral.It has the molecular mass of 60 and it's content of Si is
[tex] \frac{28}{60} [/tex]
Is that enough ?
Daniel.
No. I can't solve it.
Okay.Here goes:
28g Si---------------------------->60g SiO_{2}
x g Si------------------------------>0.484g SiO_{2}
Find "x" and then:
x g Si-------------------------->0.567g mineral
y g Si-------------------------->100g mineral
Find "y".That will be the answer to your problem
"y"% Si in the mineral...
Daniel.
So the answer is ~ 39% But I don't understand this. Can you redirect me to a good site, I've search a bit on google already.
I'm sorry,but i don't follow...Good site on what??And what exactly didn't u understand??
Daniel.
danne, this is not very hard, and you've nearly got it. I'm quite sure that the question really means "silicon dioxide" rather than "silicon oxide". All silicates (that I know of at least - like sodium, potassium, aluminum,...) are composed of SiO2 units, so this must be what they are talking about.
First of all you found out how much Si there is in SiO2. You got this to be about 46.7%. This simply means that every 100g of SiO2 will contain 46.7g of Si.
But you are told how much SiO2 there is (0.484g), so you can determine how much Si there should be in 0.484g of SiO2. This will just be 46.7% of 0.484g. What does that give you ? Divide this number by the total weight to get the required percentage.
You should get about 39.8%
46.7 * 0.484 : 0.567 = 22.6028:0.567 = 39.86 %
I'm a right now?
Yes, that's right. But you have to divide the left side by 100 to account for the percentage.
1. What is the significance of calculating % Silicon in silicate minerals?
Calculating % Silicon in silicate minerals is important because it allows us to determine the chemical composition and characteristics of the mineral. Silicon is a major element in silicate minerals and its percentage can provide information about the mineral's physical and chemical properties, such as hardness, color, and crystal structure.
2. How is % Silicon calculated in silicate minerals?
% Silicon is calculated by dividing the weight of silicon atoms in the mineral by the total weight of the mineral, and then multiplying by 100. This can be done using various analytical techniques such as X-ray fluorescence (XRF) or inductively coupled plasma (ICP) analysis.
3. What are the common silicate minerals and their % Silicon content?
The most common silicate minerals are quartz (SiO2), feldspars (60-70% SiO2), micas (40-50% SiO2), and amphiboles (40-50% SiO2). Other silicate minerals, such as olivine, pyroxenes, and garnets, have varying % Silicon content depending on their composition.
4. Why is it important to know the % Silicon in silicate minerals for geological studies?
Knowing the % Silicon in silicate minerals is important for geological studies because it can help us identify and classify minerals, understand their formation and evolution processes, and infer the conditions of their formation. It can also provide insights into the geological history and evolution of a particular region or rock formation.
5. What factors can affect the % Silicon content in silicate minerals?
The % Silicon content in silicate minerals can be affected by various factors such as the composition of the parent rock, the temperature and pressure conditions during formation, and the presence of other elements in the mineral's structure. It can also be influenced by metamorphic or weathering processes that alter the mineral's composition over time.
  • Mechanical Engineering
