Measuring Ionization Energy of Candles
In summary: Assuming that a candle combusts 100% of its wax (none is lost as unburnt vapour etc.) then the power output of such a candle = rate of energy released from combustion.
Tominator
79
Hi all,
I have been wondering how much energy does a candle produce per second. I know, that the heat energy can be measured, but what about the ionization energy? By ionization energy I mean the energy which is consumed when neutral atoms in the air are ionized.
How can the amount of ions generated by candle per second be counted?
Thanks for answers
Candle flames are not energetic enough to ionize atoms. Perhaps confusingly, the light output by a single candle is given by the unit 'candela':
http://en.wikipedia.org/wiki/Candela
A candle emits about 1/683 W per steradian; an isotropically emitting candle emits about 0.2 W.
According to the wiki on candles, a typical candle emits a combined total (light and heat) of about 77 watts:
A modern candle typically burns at a rate of about 0.1 g/min, releasing heat of about 77 W, plus or minus about 9 W.[2] The light produced is about 13 lumens. The luminous efficacy is about 0.17 lumens per watt
http://en.wikipedia.org/wiki/Candle
...though, unless I'm missing something it doesn't quite jive with another part of the article:
A candle typically produces about 13 lumens of visible light and 40 watts of heat, although this can vary depending primarily on the characteristics of the candle wick.
russ_watters said:
According to the wiki on candles, a typical candle emits a combined total (light and heat) of about 77 watts: http://en.wikipedia.org/wiki/Candle
Ah... photometric units.
http://en.wikipedia.org/wiki/Lumen_(unit )
1 lm = 1 cd*sr, so an isotropic candle emits 4*pi lm ~ 13 lm. Converting photometric (lm, lx, phot, nit..) units to radiometric (W, J, W/cm^2...) units is an exercise in frustration, but converting luminance to radiance can kinda-sorta be done by the NIST conversion I gave above. The candle article you quote gives the same conversion, but they left out the fact that the conversion occurs at the maximum response of the model human eye. Band-averaged over the spectrum, 13 lm will give less than 13* 0.17 W.
Ok, good to know where your number comes from. To clarify, though, the OP didn't ask how much light a candle produces, but rather asked how much energy it produces. So it would be on the order of 40 or 77 watts total, 38.8 or 76.8 of which as heat and the other .2 as light.
Actually, if you want to pick nits, the OP asked how many ions a candle produces, and how much energy is associated with the ionization process.
Exactly
Thanks for answering my first question. Andy, you have claimed in your first post that
Andy Resnick said:
Candle flames are not energetic enough to ionize atoms. Perhaps confusingly, the light output by a single candle is given by the unit 'candela': ...
According to my knowledge, plasma is ionized gas and candle flame is plasma... also if you put a candle between two charged plates, the flame divides into two ion streams. So if flame does not ionize the air around candle, what does?
Candles produce light and heat by combustion, which is an electrically neutral process, AFAIK. The soot, on the other hand, can apparently pick up charges from the air. I am not sure how this occurs.
The bottom line, a candle flame is not energetic enough to ionize atoms or molecules. Proof of this is the fact that candles don't produce UV or X-ray radiation.
So those ion streams generated when a candle is between charged plates are primarily caused by the voltage difference? But the heat makes the ionization process easyer, doesn`t it? (lower voltage is required)
The combustion of paraffin wax releases about 42 kJ of energy per gram. Assuming that a candle combusts 100% of its wax (none is lost as unburnt vapour etc.) then the power output of such a candle = rate of energy released from combustion.
I've had a look at various paraffin candles on the internet and compared their claimed burn times with the estimated mass of wax they comprise. I got figures which varied between about 60 W for the slowest-burning tealights and 100 W for the brightest pillar candles.
1. What is ionization energy?
Ionization energy is the amount of energy required to remove an electron from an atom or molecule, resulting in the formation of an ion.
2. How is ionization energy measured?
Ionization energy is typically measured in units of electron volts (eV) or kilojoules per mole (kJ/mol). It can be measured using various techniques such as flame photometry, mass spectrometry, or spectroscopy.
3. Why is it important to measure the ionization energy of candles?
Measuring the ionization energy of candles can provide insight into the chemical composition and energy content of the candle's wax. It can also help determine the efficiency and performance of the candle, as well as potential safety hazards.
4. Can the ionization energy of candles vary?
Yes, the ionization energy of candles can vary depending on factors such as the type of wax, additives, and wick used. It can also vary with the temperature and conditions of the burning process.
5. How can the measurement of ionization energy of candles be useful in real-world applications?
The measurement of ionization energy of candles can be useful in various industries, such as candle making, energy production, and fire safety. It can also aid in the development of more efficient and safer candle products.
  • Other Physics Topics
12K
  • Biology and Chemistry Homework Help
  • Chemistry
  • Astronomy and Astrophysics
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
