Lebesgue integral proof, prove integral is zero
In summary, we can use the Monotone Convergence Theorem to show that the limit of the integrals of f_n is equal to the integral of f, and then use the fact that f_n(x) = 0 for all x in E_n to prove that the limit is equal to 0.
jinsing
30
Suppose S is a set with finite measure, f>=0 on S and f is Lebesgue measurable. For each n in N define E_n = {x \in S | f(x) > n} Prove that \lim_{n \rightarrow \infty} \int_{E_n} f = 0
Definition of Lebesgue measurability for unbounded functions
Honestly, I'm not entirely sure where to even begin with this one. Would I want to somehow incorporate the epsilon definition of limit? Or should I define f_n(x) = f(x) if f(x) <= n and n if f(x) > n, and show that limit will equal 0? Or none of these ideas? Just a little push in the right direction would be really helpful.
Thanks!
One possible approach to proving this statement is by using the Monotone Convergence Theorem. This theorem states that if a sequence of measurable functions {f_n} converges pointwise to a function f and |f_n| <= g for all n, where g is an integrable function, then the limit of the integrals of f_n is equal to the integral of f.
In this case, we have a sequence of functions {f_n} where f_n(x) = f(x) if f(x) <= n and 0 if f(x) > n. Notice that |f_n| <= f for all n, since f_n(x) is always either equal to f(x) or 0. Also, since f is measurable and S has finite measure, f is integrable on S. Therefore, we can use the Monotone Convergence Theorem to show that the limit of the integrals of f_n is equal to the integral of f.
Now, we need to show that the limit of the integrals of f_n is equal to 0. This can be done by showing that the sequence of integrals is decreasing and bounded below by 0. Since f_n(x) = 0 for all x in E_n, we have that the integral of f_n over E_n is equal to 0 for all n. Also, since f_n(x) <= f(x) for all x in S, we have that the integral of f_n over S is less than or equal to the integral of f over S, which is a finite number. Therefore, the sequence of integrals is decreasing and bounded below by 0, which means that the limit of the integrals must be equal to 0.
Thus, we have shown that the limit of the integrals of E_n is equal to 0, which proves the statement.
1. What is the Lebesgue integral?
The Lebesgue integral is a mathematical concept used to calculate the area under a curve. It is an extension of the Riemann integral, which is limited to calculating the area under continuous functions. The Lebesgue integral can also be used to calculate the area under discontinuous functions.
2. How does one prove that the integral is zero?
In order to prove that the integral is zero, one must use the definition of the Lebesgue integral, which involves breaking down the function into smaller intervals and calculating the limit of the sums of these intervals. If the function is equal to zero on each of these intervals, then the sum will also be equal to zero, and thus the integral is zero.
3. What is the significance of proving that the integral is zero?
Proving that the integral is zero is significant because it shows that the function is "negligible" in terms of its contribution to the overall area. This can be useful in various applications, such as in probability theory where a function represents a probability distribution and the integral represents the total probability.
4. Can the Lebesgue integral be used for all types of functions?
Yes, the Lebesgue integral can be used for all types of functions, including discontinuous and non-measurable functions. This is one of the advantages of the Lebesgue integral over the Riemann integral, which is limited to continuous functions.
5. Are there any other proofs for the integral being zero?
Yes, there are several other proofs for the integral being zero, including using the monotone convergence theorem, dominated convergence theorem, and Fatou's lemma. These theorems provide alternative ways to calculate the integral and prove that it is zero.
