Use the definition of derivative to find the derivative of tan(x)
In summary, the conversation is about using the definition of derivative to find the derivative of tan(x). The formula for tan(x) is given as sinx/cosx and the question asks to use (f(x+h)-f(x))/h to find the derivative. The use of quotient rule is mentioned, and it is noted that it may also be helpful to have an equation for tan(a+b).
Willian93
use the definition of derivative to find the derivative of tan(x)
Tan(x)= sinx/cosx
i used sinx/cosx, and then use quotient rule, not sure if it is call "definition of derivative"so, is there anyway i can use f(x+h)-f(x)/h to find the derivative of tan (x)?
The question does want you to use (f(x+h)-f(x))/h, which is the definition of the derivative. That's the relevant equation. It might also be handy to have an equation for tan(a+b).
Cheers -- sylas
Related to Use the definition of derivative to find the derivative of tan(x)
1. What is the definition of derivative?
The derivative of a function at a specific point is the instantaneous rate of change of the function at that point. It represents the slope of the tangent line to the function's graph at that point.
2. How do you find the derivative of a function using the definition of derivative?
To find the derivative of a function, you must use the limit definition of derivative: f'(x) = limh→0 (f(x+h)-f(x))/h. This involves finding the slope of the secant line between two points on the function's graph and then taking the limit as the distance between those points approaches zero.
3. What is the derivative of tan(x)?
The derivative of tan(x) is sec2(x). This can be found by using the definition of derivative and the trigonometric identity: tan(x) = sin(x)/cos(x).
4. Can the derivative of tan(x) be simplified further?
Yes, the derivative of tan(x) can also be expressed as 1 + tan2(x). This is another form of the derivative that can be useful in certain situations.
5. What is the significance of finding the derivative of tan(x)?
Finding the derivative of tan(x) can be useful in many applications, such as calculating the slope of a tangent line to a curve or finding the rate of change of a trigonometric function. It also helps in understanding the behavior and properties of tan(x) and related functions.
