How is prime number programmed
  • Thread starter rajeshmarndi
  • Tags
    Prime
In summary, the conversation discusses various methods for determining the primality of a number, including checking for divisibility by known primes and using the Sieve of Eratosthenes. It also mentions the difference between a program and a formula for finding prime numbers. The conversation also touches on the applications of finding primes, particularly in cryptography and the search for Mersenne primes.
rajeshmarndi
319
If prime number doesn't have a pattern, how it is programmed to check if a number is prime or not or to display the list of prime number under a given number.
Or it just check the divisibility with each number.
Thanks.
Mathematics news on Phys.org
Here's a writeup on the various primality tests that are run to test a number's primeness:
http://en.wikipedia.org/wiki/Primality_test
Note, if the units digit of the number os 0,2,4,5,6 or 8 you know its not prime because it will be divisible by 2 or 5 or both.
So only numbers with units digit of 1,3,7,9 should be tested further.
When a number passes all the tests then you have run through the sequences of primes less than sqrt of the number.
What I am asking, is that, does these primality test, check each number with units digit of 1,3,7,9 upto less than sqrt of the number.
If not, isn't the program itself is a formula for the prime number. Because the program must be following a certain pattern in it by which the program check its primality.
Or what is the difference between a program of these primality test and a formula.
No.
Depends on how you define a formula. I guess you mean a formula to calculate the ##n##th prime. For example, you input ##n## in the formula then do some calculations and you output the ##n##th prime. The primality tests do not do that. In primality tests you input a specific number and they say whether it is prime or not. It doesn't actually give you the ##n##th prime.
There are several ways to check whether an integer is prime. The usual one is to simply to check for divisibility by every prime number up to the square root of your number, as you suggested. This is not the only one though. For large suspected primes you usually use algorithms which rely on random numbers and can with high certainty say whether a number is prime or not (usually the longer you run it the more certain you become). If you need complete certainty, then there are also other algorithms to check for primality which use more sophisticated methods and are faster for very large primes (see e.g. the APRT-CL algorithm).
I don't understand what you are getting at with regards to what the difference is between a program and a formula. A simple and naive program might look like:
PRIME(n):
  1. Set k = 2, GO TO LINE 2
  2. If k * k > n, then return "n is a PRIME", else GO TO LINE 3
  3. If k divides n, then return "n is a COMPOSITE", else GO TO LINE 4
  4. Increase k by 1 and GO TO LINE 2.
By my definition of a formula this wouldn't qualify as a formula, but I'm sure with a very broad view you could call it a formula.
But say, if there are, only few definite, if then else condition, say 4 or 5, and not an indefinite loop, the program has to go through , to find the nth prime i.e it can be done without a computer.
Will it be called a formula or a program.
Program I understand, where a loop can go indefinite times.
It all depends on your personal definition of a formula and a program.
Thanks.
Maybe less advanced than what others might know about, but:
Do an internet search on "Sieve of Eratosthenes".
The primality tests are ordered to throw out the number as fast as possible. That means they are ordered from cheap to expensive. By expensive I mean it takes the most resources to complete which usually means takes the most time to complete.
So the cheapest is "the units digit" check and the most expensive is the "divide by all known primes less than the sqrt of the number" check.
In cryptography, they would be more interested in the factors of a number and not whether its prime especially for public key cryptography but this drives the interest for finding a complete list of primes in a certain range and in particular for finding mersenne primes for their incredible number of digits.
http://en.wikipedia.org/wiki/Mersenne_primes
1. What is a prime number?
A prime number is a natural number greater than 1 that is only divisible by 1 and itself.
2. How is prime number determined using programming?
Prime numbers can be determined using programming by iterating through all numbers less than the given number and checking if they are factors of the given number. If there are no factors other than 1 and the number itself, then it is a prime number.
3. What is the most efficient way to program prime numbers?
The most efficient way to program prime numbers is by using the Sieve of Eratosthenes algorithm. This algorithm eliminates all the non-prime numbers in a given range, leaving only the prime numbers behind.
4. Can prime numbers be programmed using any programming language?
Yes, prime numbers can be programmed using any programming language as long as it has the necessary functions and data structures to perform the required operations.
5. How can I check if a large number is a prime number using programming?
To check if a large number is a prime number using programming, you can use a probabilistic primality test such as the Miller-Rabin test. This test uses random numbers to determine if a number is likely to be prime or not.
  • General Math
  • General Math
