Why are the centers of galaxies so bright?
  • Thread starter jaydnul
  • Tags
    Galaxies
In summary: Do you not see how Drakith's comment shows that to be incorrect? (Unless you define "very close" as meaning "inside the event horizon", but that would be an unusual interpretation since "inside the event horizon" is not "very close" it is IN)
jaydnul
558
If there is supposedly a super massive black hole in the center of each galaxy, wouldn't that eat all the light given off? Also, if the centers are so bright, why can't we see our galactic center from earth?
Astronomy news on Phys.org
The diameter of the black holes event horizon in the center of our galaxy is only a few dozen AU I believe. It is VERY VERY small compared with the overall size of the galaxy. On top of that it doesn't "eat light" unless the light goes into it. Since it is so small practically all the light emitted in the galaxy misses it completely.
We can't see the center of our galaxy very well because there is a lot of dust in the arms of our galaxy that block visible light. But we can use cameras to see in the infrared and below, which DOES pass through dust. In the microwave range we have enough resolution to see where the event horizon is when the black hole eats up gas and dust and whatever else spirals into it by watching the gas and dust heat up and emit EM radiation before it gets swallowed up. It's been quiet so far and hasn't had anything spiraling into it, but I believe next year there is a giant gas cloud that will start to spiral in. It should be quite a show!
physicsguy13 said:
Even if the black hole did "suck up" all of the light, we could still see the light traveling towards the event horizon.
Not true. You cannot see light unless it enters your eye or enters a sensor to be detected. Light does not bounce off of other light, so we wouldn't be able to see it.
We not only CAN see the galactic center (although not if the visible spectrum), there is a detailed plot of the orbits of stars around (very close in to) the super-massive black hole that in fact is part of the evidence that it it IS a black hole.
I'm sorry, I mispoke. Unless the star is very close to the black hole, it is likely that some of the light will come in our direction.
As long as the star is outside of the event horizon its light will reach us. This is a gross simplification, and things like tidal effects would rip apart the star if it were too close, but basically as long as the light is emitted outside of the event horizon, and it doesn't pass too close to the black hole, it will reach us. Also, perhaps you aren't realizing that light is emitted in all directions from a star. Some of the light IS going to fall into the black hole, but that is a very small fraction of the total light.
What did I say wrong then?
You weren't really "wrong", I just want to make sure you understand that unless the light is emitted inside of the black hole then it will probably be able to reach us. (Or someone else since light is emitted in all directions)
1. Why are the centers of galaxies so bright?
The centers of galaxies are typically much brighter than the outer regions due to the high concentration of stars and other luminous objects, such as active galactic nuclei. These objects produce a large amount of light and energy, making the center of the galaxy appear brighter than the rest.
2. What is an active galactic nucleus?
An active galactic nucleus (AGN) is a compact region at the center of a galaxy that emits a high amount of radiation across the electromagnetic spectrum. This emission is caused by a supermassive black hole at the center of the galaxy that is actively accreting material and releasing energy in the form of light and jets of particles.
3. How do supermassive black holes contribute to the brightness of galactic centers?
Supermassive black holes play a significant role in the brightness of galactic centers. As material falls into the black hole, it heats up and releases a tremendous amount of energy, making the center of the galaxy appear bright. Additionally, the jets of particles emitted by the black hole can also contribute to the brightness of the center region.
4. Are all galaxies equally bright in their centers?
No, not all galaxies are equally bright in their centers. The brightness of a galactic center depends on the size and type of the galaxy, as well as the presence of active galactic nuclei. Elliptical galaxies, for example, tend to have much brighter centers than spiral galaxies.
5. How do astronomers study the brightness of galactic centers?
Astronomers use a variety of instruments and techniques to study the brightness of galactic centers. These include ground-based telescopes, space-based telescopes, and specialized instruments such as spectrographs and interferometers. They can also use different wavelengths of light, such as infrared or X-ray, to study the different components of the galactic center and understand its brightness in more detail.
  • Astronomy and Astrophysics
