Creation of space what exactly does this mean
In summary, the conversation discusses the idea of "creation of space" and how it is a misleading wording in the context of general relativity. The concept of space is not a substance that can be created, but rather it is the distances between objects in a given reference frame. The conversation also delves into the role of dark matter and dark energy in the expansion of space, with dark energy being the driving force behind the accelerating expansion. The conversation concludes with the suggestion to delve into mathematical models for a deeper understanding of this complex concept."
matthias31415
"creation of space" what exactly does this mean
dear all,
I must admit, the wording "space is created" sounds to me rather unscientific (forgive me for being provocative). I know that, in general relativity, there are (more or less arbitrary) reference frames and distances within these reference frames. In terms of reference frames, distances and geometry: what does "creation of space" mean? Does it mean that a new reference frame is created? That wouldn't make much sense to me. Is it a synonym for "expansion", i.e. the fact that distances between stationary observes increase? In that case, I don't understand why people say that during the big bang, space was created alongside matter. This would imply that space was created only in the very beginning, while expansion still takes place...
can you help me?
-matthias
Space news on Phys.org
Here is one way to think:
there is no substance called "space"
instead there are distances that comprise geometry.
these distances increase according to a certain pattern
so there is no substance being created
nothing moves
geometry simply evolves according to a law discovered in 1915 called the GR field equation.
the distances increase according to a certain pattern
geometry evolves according to a law discovered in 1915 called the GR field equation.
thanks marcus, I am ready to agree with you. But what exactly do you think of the wording "creation of space". Does it do justice to what you just wrote?
I think it is a not so good translation into English from the math model.
The truth is in the math model. Any translation of anything in another language is just an approximation. Some translations are closer than others.
Since you ask, I think "creating space" is a not so good translation of the pattern of increasing distances.
It is not a stuff that anyone makes, so the words have a slightly misleading connotation and give a slightly wrong idea to the reader.
As this boffin understands it, it's not like the expanding distance between, say, two billiard balls. That's the way the average person seems to understand it. But there's a little more to it with "expansion".
If you put your two billiard balls a light year apart, then it would take a year for light to travel between the two (simplistically). But then you find out that those two billiard balls are separating at faster than light speed because space itself is expanding. Confusing huh? Had me going for a while there too.
But space (out there in the u) isn't just space. Dark matter and dark energy are hiding out in that void, driving this "expansion". Through some cosmic math that I don't quite follow, the "space" between stars is having extra space added, over and above any actual movement of the stars. It's like the billiard balls are separating under their own movement (at slower than light speed), but the billiard table itself is growing bigger, causing them to separate faster than they are under their own steam. Somehow we still get light from them because of our position as observer, which I haven't quite understood.
If I had my druthers, I would have become a mathematician when I was younger.
'Space' has no objective existence in science as we know it, it is merely the emptiness between particles in a FLRW universe.
narrator said:
... Dark matter and dark energy are hiding out in that void, driving this "expansion".
If I understand it correctly, dark matter has no relevance at all in the expansion. The expansion is attributed entirely to (1) a small amount of non-accelerating distance change that is left over from the earliest days of the universe and (2) a large and accelerating distance change due to whatever it is that we call dark energy.
Before dark energy was discovered, the belief was that the distance change due to (1) would decrease and eventually reverse due to gravity. In fact, as I recall the belief was that the reversal had already started. When it was found that the situation was quite different, with distance changes accelerating, this was attributed to "dark matter" which is a technical term meaning "hey, we have NO idea what's going on but we've got to call it something".
Well, not exactly. If you like to express it that way, then the large portion of recession velocity is what is left over from earliest days. Also, the belief was that universe is deaccelerating, and that deacceleration parameter (q) is positive. Now we know that it is negative. Nobody ever thought that reversal has already started. If you are interested in this stuff, and apparently you are, take a look at this graph: http://en.wikipedia.org/wiki/File:Friedmann_universes.svg" . That is the single most important curve in cosmology. Pay attention to the curves with ΩM only. Those describe expansion with only various matter density, but without dark energy.
Also you can play with on line cosmic calculators. They can be very helpful. My favorite is here:http://www.uni.edu/morgans/ajjar/Cosmology/cosmos.html"
Calimero said:
... Nobody ever thought that reversal has already started.
DOH ! Actually, I DID know that, but misspoke.
Thanks for the corrections and the links (I'll check out those links for sure)
thanks to all. Let me please get back to my original question about space. The question wasn't so much about expansion, rather about what the metaphor "space is being created" may reasonably denote.
Of course, chalnot's word (there is no objective space in science) is true, but the metaphor is still there and I want to get as much from it as possible.
I am particularly asking for the difference between two versions of this metaphor:
1) One is that during the big bang, space (and time and matter...) was created. E.g. German Wikipedia says "Der Urknall bezeichnet ... die gemeinsame Entstehung von Materie, Raum und Zeit aus einer ursprünglichen Singularität." ("Big Bang" denotes the joint formation of matter, space and time out of singularity).
2) The other is that space is created during expansion. A notion I am beginning to like.
While I intuitively dislike the former variant, the latter seems instructive to me. What about you (forum members, professionals, beginners...)? how do you like these metaphors? Do you feel that both variants denote the same thing?
matthias31415 said:
... Let me please get back to my original question about space. The question wasn't so much about expansion, rather about what the metaphor "space is being created" may reasonably denote.
I think the metaphor "creation" in English is bad in both cases and causes many people trouble. Primarily because of the Religious Myth association.
http://en.wiktionary.org/wiki/entstehen
In German the root meaning of Entstehung comes from the verb "to arise" entstehen. This can be natural, something can arise by itself.
If there is a craftsman or builder, one is more apt to say to make "schöpfen". So Haydn's music about the Creation Myth is called Die Schöpfung. The sense is The Making (by a Creator) and not something naturally arising or coming (by itself) into existence.
The Wiki dictionary says the translation of entstehen is
1) to come into existence
2) to arise
I said what I think about the expansion of distances around the beginning of the thread, that it is a dynamic change in geometry. Space is not a substance.
One should simply accept that distances can change, without anything being "created".
But if one feels compelled to talk about the becoming of "more space" then it would be better to use the metaphor of ARISING of space, rather than CREATION of space.
Now I have a question for you. The Potsdam branch of the Max Planck Institute has the special name of "Albert Einstein Institute". The AEI is the branch of MPI having to do with gravitation, general rel., fundamental theory etc.
They have a public outreach website called "Einstein Online". Here is an essay about the Urknall (and some confusions the public has about it.)
http://www.einstein-online.info/spotlights/big_bangs
I would like to ask you to have a look at this one-page essay and comment. Notice that they suggest that 'singularity' is not necessarily something that happens in nature. It can simply be a symptom that something is bad in the theory that suffers the singularity. A sign that one needs to fix or replace the theory.
The AEI website does not, I think, encourage you to believe that the "big bang" was the coming into existence of space, time, and matter. There is no scientific reason to believe that. Some models go back before. There may have been space time matter before the start of expansion. Just something different happening, not experiencing expansion. Please read the essay and see what you think. Maybe you won't like it! I am interested to know either way.
Chronos I believe I was told by someone here (maybe Marcus I am not sure) around 6 months ago that top Physicists were holding conferences to try to determine whether this statement is correct. I myself have gone full circle about this question after reading up about older Physics. I had a thread about it:
https://www.physicsforums.com/showthread.php?t=487911&highlight=properties+of+space
Marcus thanks for the Einstein online link
*'Space' has no objective existence in science as we know it, it is merely the emptiness between particles in a FLRW universe.*
Tanelorn said:
Chronos I believe I was told by someone here (maybe Marcus I am not sure) around 6 months ago that top Physicists were holding conferences to try to determine whether this statement is correct...
I think Chronos is right from a GR perspective. The catch is we don't know for sure that GR is a correct picture of Nature in every regard. But in many contexts we tend to assume it is.
In the world as described by GR, points in space have no physical existence, but geometry does. GR is about the evolution of geometry as it interacts with matter.
Geometry does not require a material space substance----it can simply be about the geometric relations among events, about the geometric measurements we make (area, angle, volume etc.) involving actual material, about the other fields that live in a given geometry. It means something operational and definite without being a substance.
I think that is the GR view of it. Someone may want to correct me on this---what I said may be wrong or incomplete.
The catch is we aren't sure if GR is the whole story and if it is going to be replaced what the main features of the replacement are.
As I see it, standard matter physics MIGHT fit nicely into GR. It is about matter fields. Why couldn't the matter fields live happily in GR geometry? It hasn't been like that. Quantum field theory is usually done in a fixed geometry, not a dynamically changing expanding contracting etc geometry. But maybe the theorists can work that out. Or they can first quantize the GR geometry and then get matter fields to live in it.
Or both have to change----both matter physics and geometry physics have to change a little in order to be compatible.
You could say that is what some of the conferences have been about. I could have been talking about the June 2011 one in Zurich called "Quantum theory and gravitation." It brought together people from quite a number of research lines all having to do, one way or another, with this problem.
thanks Marcus, yes I think that was the conference now I recall.
Creation of space, a'la expansion, as I understand it, if you take away the religious connotations (please), seems fine with me. Without the energy or whatever is doing it, objects would be moving apart in regular fashion (if such a thing could even happen, given current understanding). So in a sense, DM or DE (whichever is doing it) is "creating" more space than would be there without it.
But in the sense that there is nothing in space to expand, then the true sense has to be that DM or DE is putting greater distance between objects than their relative movement can account for, given the limits of c. And my understanding is that the mechanism that does this must somehow be impacting on the forth dimension - time.
Perhaps it's an exercise in semantics, but if we understand what we really mean, then we can get past that.
DM is what allows for structure formation in the universe, it does not contribute to expansion. Without DM, there is simply not enough mass in the universe to allow the mass density necessary for stars, galaxies, etc., to form after the big bang.
Narrator, I think the point that is being made is that space has no objective existence whatsoever, it is just a measurement of distance between two points which is not constant with time due to the complexities of spacetime and also dark energy expansion. Space time is therefore not like ponderable matter, it doesn't need to be created.
Barring the semantics, I think that's pretty much what I said.
But as for the semantics, when your wife asks you to move some of the boxes aside in the closet to make room for her shoes, she might use the words, "to create some space for my shoes darling."
matthias31415 said:
dear all,
can you help me?
-matthias
Creation of distance means that there is more distance between galaxies. In a very rough way, if at t1 the distance is S at t2 the distance is 2·S for instance.
Did you never hear of the balloon analogy?
juanrga said:
Creation of space means that there is more space between galaxies. In a very rough way, if at t1 the space is S at t2 the space is 2·S for instance.
I think your point would be better made if you replaced the bolded space with "distance", since that's what's actually the case. "Space" is not a helpful word in this regard.
Thank you. made
Related to Creation of space what exactly does this mean
1. What is the creation of space?
The creation of space refers to the development of the vast expanse of the universe, including all matter, energy, and the physical laws that govern them. It is believed to have occurred during the Big Bang, an event that is thought to have taken place approximately 13.8 billion years ago.
2. How did space come into existence?
The most widely accepted scientific theory is that space was created during the Big Bang. This theory suggests that all matter, energy, and space itself were initially condensed into a singularity, which then expanded rapidly, giving rise to the universe as we know it.
3. What is the role of gravity in the creation of space?
Gravity played a crucial role in the creation of space. As the singularity expanded, gravity caused matter and energy to clump together, forming the first stars and galaxies. This process continues to shape the structure of the universe today.
4. Is space constantly expanding?
Yes, space is expanding at an accelerating rate. This expansion is believed to be driven by dark energy, a mysterious force that makes up about 70% of the total energy in the universe. However, on a smaller scale, the force of gravity can cause objects to appear to move closer together.
5. Can space be created or destroyed?
According to the laws of physics, space cannot be created or destroyed. However, it can expand or contract through the influence of gravity and other forces. The amount of space in the universe is thought to be infinite, but it is constantly changing and evolving.
  • Cosmology
