Relativistic frequency shift of satellite signal
In summary, the relativistic frequency shift of a satellite signal is affected by both time dilation and the gravitational blueshift. The radius of the satellite's orbit is 2.656 x 10^7 meters and its speed is 3874 meters per second. The fractional change in frequency due to time dilation is -1.292 x 10^-5, while the fractional change due to gravitational blueshift is 5.281 x 10^-10. The overall fractional change in frequency is -1.292 x 10^-5. The relativistic frequency shift equation is generally applicable, but for this specific problem, the frequency shift due to time dilation can be found using a simpler equation by assuming orthogonal motion.
jonmack3
An Earth satellite used in the Global Positioning System moves in a circular orbit with period 11 h 58 min. (a) Determine the radius of its orbit. (b) Determine its speed. (c) The satellite contains an oscillator producing the principal nonmilitary GPS signal. Its frequency is 1575.42 MHz in the reference frame of the satellite. When it is received on the Earth's surface, what is the fractional change in this frequency due to time dilation, as described by special relativity? (d) The gravitational blueshift of the frequency according to general relativity is a separate effect. The magnitude of that fractional change is given by
##\frac{\delta f}{f} = \frac{\delta U_g}{mc^2}##
where ##\delta U_g/m## is the change in gravitational potential energy per unit mass between the two points at which the signal is observed. Calculate this fractional change in frequency. (e) What is the overall fractional change in frequency?
##c = 2.998\times 10^8 m/s\\
G = 6.671\times 10^{-11}\frac{Nm^2}{kg^2}\\
r_{Earth} = 6.3781\times 10^6 m\\
m_{Earth} = 5.97219\times 10^{24} kg\\##
##F_g = \frac{Gm_{sat}m_{Earth}}{r^2}\\
F_c = \frac{m_{sat}v^2}{r}\\
rate = \frac{distance}{time}\\
f_{obs} = \frac{\sqrt{1 + \frac{v}{c}}}{\sqrt{1 - \frac{v}{c}}}f_{source}\\
t' = \gamma t = \frac{t}{\sqrt{1 - \frac{v^2}{c^2}}}\\
T = \frac{1}{f}\\
fractional\ change = \frac{f_{new}-f_{original}}{f_{new}}\\
U = \frac{Gm_{sat}m_{Earth}}{r}##
(a) ##F_{sat} = 0 = F_c - F_g = \frac{m_{sat}v^2}{r} - \frac{Gm_{sat}m_{Earth}}{r^2}\\
\frac{m_{sat}v^2}{r} = \frac{Gm_{sat}m_{Earth}}{r^2}\\
v^2 = \frac{Gm_{Earth}}{r}\\
rate_{sat} = \frac{distance_{sat}}{time_{sat}} = \frac{2\pi r}{T}\\
\frac{Gm_{Earth}}{r} = v^2 = (\frac{2\pi r}{T})^2 = \frac{4\pi^2r^2}{T^2}\\
r^3 = \frac{Gm_{Earth}T^2}{4\pi^2}\\
r = \sqrt[3]{\frac{Gm_{Earth}T^2}{4\pi^2}}\\
r = \sqrt[3]{\frac{(6.671\times 10^-11\frac{Nm^2}{kg^2})(5.97219\times 10^{24} kg) (43080s)^2}{4\pi^2}} = 2.656 \times 10^7 m##
(b) ##v = \frac{2\pi r}{T} = \frac{2\pi(2.656\times 10^7m)}{43080s} = 3874 m/s##
(c) ##fractional\ change = \frac{f_{new}-f_{original}}{f_{original}}\\
f_{new} = \frac{\sqrt{1 + \frac{v}{c}}}{\sqrt{1 - \frac{v}{c}}}f_{original}\\
fractional\ change = \frac{\frac{\sqrt{1 + \frac{v}{c}}}{\sqrt{1 - \frac{v}{c}}}f_{original}-f_{original}}{f_{original}}
=\frac{\sqrt{1 + \frac{v}{c}}}{\sqrt{1 - \frac{v}{c}}}-1\\
=\frac{\sqrt{1 + \frac{3874m/s}{2.998\times 10^8m/s}}}{\sqrt{1 - \frac{3874m/s}{2.998\times 10^8m/s}}}-1 = -1.292\times 10^{-5}##
(d) ##\frac{\Delta f}{f} = \frac{\Delta U_g}{mc^2}
= \frac{U_{satellite} - U_{surface}}{mc^2}\\
= \frac{\frac{Gm_{satellite}m_{Earth}}{r_{orbit}} - \frac{Gm_{satellite}m_{Earth}}{r_{surface}}}{m_{satellite}c^2}\\
= \frac{Gm_{Earth}}{c^2}\left({\frac{1}{r_{orbit}} - \frac{1}{r_{surface}}}\right)\\
= \frac{\left(6.671\times 10^-11\frac{Nm^2}{kg^2}\right)(5.97219\times 10^ {24}kg)}{(2.998\times 10^8m/s)^2}\left(\frac{1}{6.3781m} - \frac{1}{2.656\times 10^7m}\right)\\
= 5.281\times 10^{-10}##
(e) ##fractional\ change_{total} = fractional\ change_{special} + fractional\ change_{general} = -1.292\times 10^{-5} + 5.281\times 10^{-10} = -1.292\times 10^{-5}##
The problem I'm having is with part (c) (and by extension, then, part (e)). This question comes from a book (Modern Physics, 3rd edition, Serway, Chapter 1, #39), and its answers are in the back of the book. My answers for (a) and (b) match with the back within calculator error, but its answer for (c) is -8.34 x 10-11. I've looked online for help on this problem, and found the following solution at http://web.unbc.ca/~hussein/Phys_205_Fall_2004/Selected_Ch01.pdf:
##T = \gamma T'\\
f = \frac{1}{T}\\
fractional change = \frac{f-f'}{f}' = \frac{\frac{1}{T} - \frac{1}{T'}} {
{\frac{1}{T'}}}
=\frac{\frac{1}{\gamma T'} - \frac{1}{T'}} {{\frac{1}{T'}}}
=\frac{1}{\gamma} - 1 = \sqrt{1-\frac{v^2}{c^2}}-1\\
=\sqrt{1-\frac{(3874m/s)^2}{(2.998\times 10^8m/s)^2}} - 1 = -8.35\times 10^{-11}##
My issues, then, are the following:
My attempt at part (c) seems correct (if for no other reason than that it only requires use of one equation given in the book, as opposed to having to derive one), but gives an answer far different than that in the back of the book. Is the back incorrect?
The pdf answer is far closer to the given one, but it doesn't make sense why that should be the case: this is a relativistic frequency shift question, so the relativistic frequency shift equation (as I used) should provide the answer. Is the pdf answer correct?
If the relativistic frequency shift equation isn't applicable here, when *would* it be applicable? It seems the pdf derivation could be used everywhere there's a relativistic frequency shift, and since it's a different equation, it implies to me that one equation is generally correct for all of these types of problems, and one isn't. Is that the case? And if so, does that mean that the relativistic frequency shift equation is simply incorrect, or generally inapplicable?
Thanks in advance for any assistance!
Your equation requires that the satellite moves directly towards the observer (or directly away). That would make the satellites crash - not good for the system.
The question asks for the frequency shift due to time dilation only. This is equivalent to the frequency shift with a perfectly orthogonal motion (satellite motion relative to viewing direction).There is a more general formula for arbitrary angles between line of sight and relative motion, but that is not needed here.
That answered my question. Thank you!
1. What is the relativistic frequency shift of satellite signal?
The relativistic frequency shift of satellite signal is a phenomenon in which the frequency of electromagnetic signals emitted by a satellite in motion is altered due to the effects of special relativity. This shift occurs because the speed of the satellite affects the perceived time and distance of the signal by an observer on Earth.
2. How does the relativistic frequency shift affect satellite communication?
The relativistic frequency shift can cause errors in satellite communication systems if not accounted for. Because the frequency of the signal is altered, it can lead to incorrect time measurements and data transmission errors. Therefore, it is important for satellite communication systems to take into account the relativistic frequency shift in order to ensure accurate communication.
3. What factors contribute to the relativistic frequency shift?
The relativistic frequency shift is primarily caused by the speed of the satellite and the strength of Earth's gravitational field. As the satellite moves at high speeds and experiences different levels of gravitational pull, the frequency of its signals will be altered. Other factors such as the satellite's distance from Earth and the curvature of spacetime also play a role in the relativistic frequency shift.
4. Can the relativistic frequency shift be observed in everyday life?
Yes, the relativistic frequency shift can be observed in everyday life. For example, the GPS system that we use for navigation relies on satellites sending signals to receivers on Earth. These signals experience a relativistic frequency shift, which needs to be corrected for in order to accurately determine position and time. Additionally, the Global Positioning System (GPS) satellites are equipped with precise atomic clocks that are adjusted for the effects of the relativistic frequency shift.
5. How is the relativistic frequency shift calculated and accounted for in satellite communication?
The relativistic frequency shift is calculated using the Lorentz transformation equations from special relativity. These equations take into account the speed of the satellite, the strength of Earth's gravitational field, and the distance between the satellite and Earth. To account for the relativistic frequency shift in satellite communication, correction factors are applied to the satellite's clock and the signals it sends to Earth. These correction factors are carefully calculated and adjusted to ensure accurate communication and data transmission.
