Electric Potential of grounded hollow metal sphere
In summary, we have a solid metal ball of radius 'a' with charge Q placed inside a hollow metal sphere with inner radius 'b' and outer radius 'c'. The sphere is grounded, meaning the electric potential is zero at r = c. The electric potential V is equal to U/q0 and can also be calculated using the equation V = 1/4πε0 ∫ dq/r. The electric field is zero inside the grounded metal sphere and all four cases in the attempted solution will have the same result, V = Q/4πε0r. At r = b, the charge on the metal shell is equal to the charge on the inner metal ball minus the charge on the hollow space between r = a
ti-84minus
There is a solid metal ball of radius 'a' (with charge Q) that is placed inside a hollow metal sphere (inner radius = 'b', outer radius = 'c'). The metal sphere is grounded (so V = 0 at r = c).
a) Find the electric potential V everywhere.
b) Find the charge on the metal shell at r = c and r = b.
V = U/q0.
V = [itex]\frac{1}{4\pi\epsilon_{0}}\int\frac{dq}{r}[/itex]
I considered the problem case by case:
r<a : V = [itex]\frac{Q}{4\pi r\epsilon_{0}}[/itex]
a<r<b
b<r<c
r>c
Would the other three cases have the same result, since electric field is zero when b<r<c and r>c? (actually, when r>c, IS the electric field zero, since the sphere is grounded?)
Thanks for your help!
Thank you for your post. I would like to provide some input on your question.
First of all, your equations for electric potential are correct, but I would like to clarify the meaning of the symbols. V represents the electric potential, U represents the potential energy, q0 represents the test charge, and dq represents an infinitesimal charge element. Also, I would like to point out that the electric potential is a scalar quantity, not a vector as the electric field is.
Now, to answer your question, yes, the electric field is indeed zero inside the grounded metal sphere. This is because the electric field inside a conductor is always zero, and since the metal sphere is grounded, it is considered as a conductor. Therefore, all four cases in your solution will have the same result, which is V = Q/4πε0r.
For part b), the charge on the metal shell at r = c will be equal to the charge on the inner metal ball, which is Q. This is because the metal shell is grounded, so the charge on the inner metal ball will spread out evenly over the entire surface of the metal shell.
At r = b, the charge on the metal shell will be equal to the charge on the inner metal ball minus the charge on the hollow space between r = a and r = b. This can be calculated using the equation for electric potential that you have provided.
I hope this helps to clarify your understanding of the problem. If you have any further questions, please do not hesitate to ask.
1. What is the electric potential of a grounded hollow metal sphere?
The electric potential of a grounded hollow metal sphere is equal to zero at all points on the surface of the sphere. This is because the sphere is connected to the ground, which is considered to have an electric potential of zero.
2. How does the electric potential vary inside a grounded hollow metal sphere?
Inside a grounded hollow metal sphere, the electric potential is constant and equal to the potential at the surface of the sphere. This is because the electric field inside a conductor is zero, and the electric potential is directly related to the electric field. Therefore, the potential inside a conductor is constant.
3. Can the electric potential of a grounded hollow metal sphere be changed?
Yes, the electric potential of a grounded hollow metal sphere can be changed by changing the potential of the object that is connected to the ground. For example, if a charged object is brought near the sphere, the potential of the sphere will change due to the influence of the external electric field.
4. How does the size of a grounded hollow metal sphere affect its electric potential?
The size of a grounded hollow metal sphere does not affect its electric potential. The potential at the surface of the sphere will always be zero, regardless of the size of the sphere. However, the electric field inside the sphere will be stronger for a smaller sphere, as the charge is more concentrated.
5. Can the electric potential of a grounded hollow metal sphere be negative?
No, the electric potential of a grounded hollow metal sphere cannot be negative. The potential at the surface of the sphere is always zero, and the potential inside the sphere is constant, meaning it cannot change to a negative value. However, a charged object near the sphere can create a negative potential relative to the sphere's potential.
