Tight Binding Description of Graphene (Hamiltonian and Overlap Matrix)
In summary, a tight binding description of graphene is a theoretical model used to describe the electronic structure of the two-dimensional material. It involves constructing a Hamiltonian and overlap matrix to account for the interactions between the electrons and the atoms in the honeycomb lattice. The Hamiltonian is constructed by considering the energy levels of carbon atom orbitals, while the overlap matrix represents the interactions between neighboring atoms. This description accounts for the unique properties of graphene, such as its Dirac cone-shaped energy dispersion and zero band gap. It has important applications in fields such as electronics, energy storage, and biomedicine, and can also be used to study other two-dimensional materials with similar electronic structures.
nyxynyx
35
http://edu.ioffe.ru/register/?doc=galperin/l3pdf2.tex
I don't understand how do you get from equation 21 to 22? How did the summations of exponentials becomes cosine functins?
Using the values of the I, the summations can be seen to be geometric series. If you do them explicitly, you will recover the cosines.
exponent of imaginary is summation of sine and cosine of real
exp(ix)+exp(-ix) = 2cos(x)
1. What is a tight binding description of graphene?
A tight binding description of graphene is a theoretical model used to describe the electronic structure of graphene, a two-dimensional material made of carbon atoms arranged in a honeycomb lattice. It involves constructing a Hamiltonian and overlap matrix to describe the interactions between the electrons and the atoms in the lattice.
2. How is the Hamiltonian for graphene constructed?
The Hamiltonian for graphene is constructed by considering the energy levels of the atomic orbitals of carbon atoms within the graphene lattice. These energy levels are then combined to create a matrix that describes the energy of the electrons in the material.
3. What is the overlap matrix in a tight binding description of graphene?
The overlap matrix in a tight binding description of graphene represents the overlap of the atomic orbitals between neighboring carbon atoms in the lattice. It is used to account for the interactions between the electrons in the material and their surrounding atoms.
4. How does the tight binding description of graphene account for the unique properties of the material?
The tight binding description of graphene takes into account the unique electronic structure of the material, such as its Dirac cone-shaped energy dispersion and its zero band gap. These properties are a result of the specific arrangement of carbon atoms in the honeycomb lattice and the interactions between the electrons and atoms described by the Hamiltonian and overlap matrix.
5. What are the applications of the tight binding description of graphene?
The tight binding description of graphene is important for understanding the electronic properties of graphene, which has potential applications in fields such as electronics, energy storage, and biomedicine. It can also be used to study and predict the behavior of other two-dimensional materials with similar electronic structures.
  • Atomic and Condensed Matter
  • Materials and Chemical Engineering
  • Quantum Physics
