Calculating resistance from a graph
In summary, the resistance of a lamp is not the same as the resistance of a resistor. You would need to figure out what the operating point is (what current are you running at -- what point are you at on the graph?), and use ΔV/ΔI at that point.
JizzaDaMan
48
Hi, i have a graph with voltage (y axis) plotted against current (x axis) and I need to calculate the resistance of a resistor and a lamp from this.
My physics teacher has told me that by Ohm's law, R = V/I, and he has also told me that on the graph, the resistance is the gradient of the graph.
The graph for the resistor is linear, so V/I is the same as the gradient, I have no problem with this. However, the graph for the lamp is non linear, so V/I isn't the same as the gradient.
What's the correct answer here? Am I missing something blindingly obvious? Thanks for any help
Good question. You would need to figure out what the operating point is (what current are you running at -- what point are you at on the graph?), and use ΔV/ΔI at that point. Does that make sense?
It makes perfect sense to me :D but what doesn't is that if I calculate the gradient at that point, it isn't the same as V/I. surely this contradicts Ohm's law?
Why do you say that? And don't call me Shirley.
Well if the resistance of the lamp is ΔV/ΔI at any point on the graph, then given that the relationship between the voltage and current for the lamp is non-linear, this will not be V/I which by Ohm's law is the formula for resistance.
The original definition of Ohms Law was just the linear equation V=IR. But it can be generalized to describe an Impedance Z which is ∂V/∂I. This is used all the time in EE. We talk about the "Impedance at a point" pretty frequently (because there are many non-linear circuits that you will work with...).
Ohm's Law only describes the behaviour of a metal at constant temperature. That's all. The Resistance of a component is defined as V/I but, of course, as V changes, this WILL change for a non-linear component (by definition).
There is no violation of any law here because Ohm's Law is not really a physical 'Law', in any case - it is just an observation of how a certain material tends to behave under given conditions.
For 'small signals', many non-linear components behave as if they have a 'resistance' because ∂V/∂I happens to be more or less constant over a particular range of V. So, under certain circumstances, we can assign a value for R and work with it.
EE does this all the time. We use 'current sources' and 'voltage sources' all the time and it works very well in practical terms and it's the same sort of thing. You must not let it spoil your day - just be glad that the system works so well.
Thank you guys, I'm pretty sure I understand that now :)
1. How do I calculate resistance from a graph?
To calculate resistance from a graph, you will need to use Ohm's Law, which states that resistance (R) is equal to voltage (V) divided by current (I). On a graph, resistance can be found by dividing the change in voltage (ΔV) by the change in current (ΔI).
2. What units are used to measure resistance?
The unit of measurement for resistance is the ohm (Ω). This is represented by the Greek letter omega (Ω) and is equivalent to one volt per ampere (V/A).
3. Can resistance change on a graph?
Yes, resistance can change on a graph as it is affected by factors such as temperature, material, and length of the conductor. For example, as the length of a wire increases, the resistance also increases.
4. How do I find the slope of a resistance vs. current graph?
The slope of a resistance vs. current graph can be found by dividing the change in resistance (ΔR) by the change in current (ΔI). This slope represents the resistance value.
5. Can I use a resistance vs. voltage graph to calculate resistance?
Yes, you can use a resistance vs. voltage graph to calculate resistance by using the formula R = V/I, where V is the voltage and I is the current. The resistance value can be found by determining the slope of the line on the graph.
  • Electrical Engineering
  • Other Physics Topics
