MrBlue
- 1
A 5hp, 1755rpm, WEG Motor (part #00518OP3E184T) needs to turn another shaft that is 12" away at 1000rpm.
Torque=HP*5252/RPM
T=F*r -> F=T/r
Drive Ratio = Driver Pitch Diameter/Driven Pitch Diameter
Sum Forces
Sum Moments
I plan on using a pulley (aka sheave) system with v-belts. I want to use a 8" sheave (7.95" pitch diameter) on the motor and a 14" sheave (13.95" pitch diameter) on the shaft that needs to turn 1000rpm. This will give me a Drive Ratio of .5714.
1755rpm*.5714=1000rpm --- Which is what I want.
My problem is, I don't know how to figure out the loads in the shaft. Since I know the torque in the motor (Torque = 5hp*5252/1755rpm=14.96ft*lb=179.52in*lb), I thought I might be able to figure out a force at a point on the motor sheave diameter by knowing that T=F*r so that F=T/r. However, when I do the calculations, I get that the force on a point on the outside of the sheave is F=179.52in*lb/(8in/2)=44.88lb. This sounds like too small of a force.
I also think that that might not even be what I need. I think I need to figure out the tension in the v-belt? Basically I need to figure out how many v-belts I need (do I need just 1 belt or 2 or 3, etc.?), and the loads on the shaft that I need to spin at 1000rpm. If I can get the resulting loads on the shaft, I can figure out the type of bearings I need to support the shaft and such.
I don't know where to go with this and could greatly use some help. Any help at all would be helpful. Thanks so much in advance.
