Finding Volume using integration
In summary, to find the volume of the solid formed by rotating the region enclosed by (e^(1x)+2)/y=0/x=0/x=.9 about the y-axis, you can use the disk method. The formula for volume is V=pi*int((f(x)^2) dx from bounds a to b. By plugging in the given x values, we can find the corresponding y values which will be our new bounds for integration. The correct answer for the volume is 6.125pi.
Mcbrown108
Find the volume of the solid formed by rotating the region enclosed by:
about the y axis
Probably disk method i would assume:
V= pi*int(e^(1x)+2)^2) a=0 b=.9
v=pi*int(e^(2x)+4) a=0 b=.9
v=pi*(1/2e^(2x)+4x)
v=pi*(1/2e^(2(.9))-(1/2e^0)+(4(.9)
v=pi*(3.025)-(1/2)+3.6
v=6.125pi
But my answer is not correct.
about the y axis
Hi Mcbrown108! :smile:
Isn't that for rotation about the x-axis? :cry:
Oh yeah. so then would i change my bounds to a=-.9 b=.9
that doesn't seem to work either
It's not your bounds that are wrong … it's your discs.
Your discs should be "horizontal" discs, centred on the y-axis. :smile:
So i should plug in the given x's to get y's for my bounds?
I've no idea what that means, but I'm going to guess the answer is … "YES!"
Go for it! :smile:
1. What is the concept of volume?
The concept of volume is the amount of space occupied by a three-dimensional object. It is usually measured in cubic units such as cubic meters (m3) or cubic centimeters (cm3).
2. How is integration used to find volume?
Integration is a mathematical tool used to find the area under a curve. By applying integration to a three-dimensional object, we can find the volume enclosed by the object.
3. What is the formula for finding volume using integration?
The formula for finding volume using integration is V = ∫ A(x) dx, where V is the volume, A(x) is the cross-sectional area of the object at a given position x, and the integral is taken over the range of x values that make up the object's dimensions.
4. Can integration be used to find the volume of any shape?
Yes, integration can be used to find the volume of any shape as long as the cross-sectional area can be expressed as a function of the position along the object. This includes both regular and irregular shapes.
5. What are some real-world applications of finding volume using integration?
Finding volume using integration has many real-world applications, such as calculating the volume of a chemical solution in a beaker, determining the displacement of a ship or submarine, and calculating the volume of a 3D printed object. It is also commonly used in engineering and architecture to determine the volume of structures and objects.
