One-to-one Correspondence Questions
  • Thread starter kolssi
In summary, you are trying to find a one-to-one correspondence between the set of whole numbers and the set of positive whole number powers.
kolssi
I haven't taken a math class for a few years now (since calc. II), and I am currently enrolled in a cryptology/math history course that has posed me a few challenges. I am not sure, but I am guessing that one of the reasons to show a one-to-one correspondence between two sets (I'm not sure 'set' is the right term) is to show that both sets are the same size? I think what I need to do is show that each element in the first set corresponds to another element in a second set.
I have read the sticky posts, and I understand that this website does not provide solutions to problems, but any hints or assistance would be greatly appreciated.
OK... so the questions.
1. Find a one-to-one correspondence between the set of natural numbers and the positive whole number powers of 10.
2. Find a one-to-one correspondence between the set of natural numbers and the whole number powers of 10.
3. Find a one-to-one correspondence between the numbers in the closed interval [0,1] and the numbers in the closed interval [3,8]. A word on notation: the closed interval [a,b] is the set of numbers x such that a <=x <= b; it includes the numbers a and b.
4. Find a one-to-one correspondence between the set A of reciprocals of the positive integers and the set B consisting of 0 and the reciprocals of the positive integers.
5. Find a one-to-one correspondence between the numbers in the closed interval [0,1] and the open interval (0,1). Notation: the open interval (a,b) is the set of numbers x such that a < x < b; it excludes both a and b.
1. I was able to figure out 1.
The two sets are 1 2 3 4 5 ... n and 10^1 10^2 10^3 ... 10^n
So the 1-to-1 correspondence is n <----> 10^n
2. The two sets here are 1 2 3 4 5 ... n and ... 10^-1 10^0 10^1 10^2 ...
I am not sure how to address the second set (whole number powers of 10) Since it does not have a defined beginning or end...
3. So these two sets are [0,1] and [3,8]
I found that for each x in [0,1] there is a 5x+3 in [3,8], but I am not sure as to the correct way to express this as a 1-to-1 correspondence.
4. So the two sets here are:
A: 1/1 1/2 1/3 1/4 ... 1/n?
B: 0 1/1 1/2 1/3 1/4...
I am not sure how to show these two sets relate. At first I thought set B was 1/(n-1) but that would result in dividing by zero for the first element in the set... So I am not sure where to go from here.
5. Upon discussion with my professor, this is the advice I have so far gathered.
So the numbers in (0,1) come in two flavors: there are those numbers of
the form 1/n where n is a whole number greater than 1 (that is, ½, 1/3,
¼,…) and those numbers not of this form. Let C be the numbers not of
the form ½, 1/3, ¼,..).
Then the numbers in [0,1] also come in two flavors: flavor one are those
of the form 0,1, 1/2 , 1/3, ¼,… and flavor two consists of exactly those
numbers in C.
So I have learned that to get the desired one-to-one correspondence between (0,1) and [0,1], I must first
pair up the numbers ½, 1/3, ¼,1/ 5,… with the numbers 0,1,1/2, 1/3,
¼,1/5,… and then pair up each number in C with itself).
I am not sure how to pair up these numbers and I am also unsure what it means to pair C with itself, so any advice here would also be appreciated.
I apologize for the rather long series of questions. Thank you in advance!
You've confused the whole numbers with the integers. The whole numbers are 0, 1, 2, ...
You want to give a one-to-one function f:[0,1]->[3,8]; that is, just write it as you normally would write a function.
You don't have to use a single formula to describe the correspondence. It's perfectly fine to say: f(1/n)=1/(n-1) when n is not equal to 1 and f(1/1)=0.
numbers in C.
So I have learned that to get the desired one-to-one correspondence between (0,1) and [0,1], I must first pair up the numbers ½, 1/3, ¼,1/ 5,… with the numbers 0,1,1/2, 1/3,
¼, 1/5, … and then pair up each number in C with itself.
Hint: Part of problem 5 is very similar to problem 4.
OK so I made some attempts at solutions. If someone could tell me if I am going in the right direction, that would be great.
I have done some reading and I found the Schroder-Bernstein theorem that I think states that for two sets A and B, if injective functions A-->B and B-->A exist, then A and B have one-to-one correspondence (bijection). I hope this can apply to my homework. I just wanted to know if I am going about this in a correct manner.
Find a one-to-one correspondence between the set of natural numbers and the whole number powers of 10. (my professor said that by "whole numbers" he means all integers)
Set A: 1,2,3,4,5,6...
Set B: ...10^-2 , 10^-1 , 10^0 , 10^1 , 10^2...
A-->B
f(1) = 10^0
f(2n) = 10^n for n >= 1
f(2n+1) = 10^-n for n >= 1
B--->A
f(10^0) = 1
f(10^n) = 2n for n>=1
f(10^-n) = 2n+1 for n>=1
I tried to match all even numbers in set A with the positive whole number powers of 10 and the odd numbers with the negative whole number powers of 10. 1 from A and 10^0 from B were left over, so I matched those two together.
***** Find a one-to-one correspondence between the numbers in the closed interval [0,1] and the numbers in the closed interval [3,8]. A word on notation: the closed interval [a,b] is the set of numbers x such that a <=x <= b; it includes the numbers a and b.
A: [0,1]
B: [3,8]
A-->B
f(x) = 5x+3
B-->A
f(x) = (x-3)/5
******* Find a one-to-one correspondence between the set A of reciprocals of the positive integers and the set B consisting of 0 and the reciprocals of the positive integers.
A: 1/1, 1/2, 1/3...
B: 0, 1/1, 1/2, 1/3...
A-->B
f(1) = 0
f(1/n) = 1/(n-1) for n>1
B-->A
f(0) = 1
f(1/n) = 1/(1+n)
*******Find a one-to-one correspondence between the numbers in the closed interval [0,1] and the open interval (0,1). Notation: the open interval (a,b) is the set of numbers x such that a < x < b; it excludes both a and b.
A: [0,1]
B: (0,1)
C: {0, 1, 1/2, 1/3,...,1/n,...}
A-->B
f(0) = 1/2
f(1/n) = 1/(n+2) for n >=1
f(x) = x for x in [0,1] that do not belong to C
B-->A
f(1/2) = 0
f(1/n) = 1/(n-2) for n>2
f(x) = x for x in (0,1) that do not belong to C
Looks good!
What is one-to-one correspondence?
One-to-one correspondence is a concept in mathematics and computer science where each element in one set is paired with exactly one element in another set. This pairing must be such that each element in one set is used only once and each element in the other set is used at least once.
Why is one-to-one correspondence important?
One-to-one correspondence is important because it allows us to establish a clear and precise relationship between two sets. This is useful in various fields such as mathematics, computer science, and statistics, as it helps us understand and analyze data more accurately.
What are some examples of one-to-one correspondence?
Some examples of one-to-one correspondence include matching numbers to their corresponding names (1 to "one"), matching letters to their corresponding sounds (A to /a/), and matching objects to their corresponding categories (apple to fruit).
How is one-to-one correspondence different from one-to-many correspondence?
One-to-one correspondence involves a one-to-one relationship between two sets, meaning each element in one set is paired with exactly one element in the other set. On the other hand, one-to-many correspondence allows for multiple elements in one set to be paired with one element in the other set.
How can one-to-one correspondence be used in everyday life?
One-to-one correspondence can be used in everyday life for tasks such as counting objects, matching names to faces, and organizing data. It is also used in various fields such as education, business, and research to establish clear relationships and make accurate comparisons between different sets of data.
