Is there an absolute maximum value of this function?
In summary, the conversation discusses the function f:R^2->R and its absolute maximum value on the set s={(x,y):/x/+/y/<=2}. The conversation also mentions the use of the Extreme Value Theorem and the difficulty in finding the boundary of s.
pantin
Consider the function f:R^2->R defined by f(x,y)=[e^(x+y)]-y+x. Is there an absolute maximum value of f on the set s={(x,y):/x/+/y/<=2}? Justify.
note, /x/ is the absolute value of x.
a. If f is con't, it takes compact sets to compact sets.
b.Extreme value thm: Suppose s belongs to R^n is compact and f: s->R is continuous. then f has an absolute min value and an absolute max value on S
My idea is
=>show s is bounded and closed => therefore compact => f con't maps compact sets to compact sets => EVT
but I encounted problem when finding boundary of s
/x/+/y/<=2 that means /x/<=2 when y=0 and /y/<=2 when x=0. then can I find the boundary here by constructing a circle with x and y? because I saw other example did it on this way.
Help..
1. What does "absolute maximum value of a function" mean?
The absolute maximum value of a function is the highest point on the graph of the function. It is the largest output value that the function can produce within a given range of input values.
2. How do you find the absolute maximum value of a function?
To find the absolute maximum value of a function, you can use calculus by taking the derivative of the function and setting it equal to 0. Then, you can solve for the critical values and plug them back into the original function to determine the absolute maximum value.
3. Is the absolute maximum value of a function always unique?
No, the absolute maximum value of a function may not always be unique. A function may have multiple local maximum points, which are points that are higher than all the surrounding points but not necessarily the highest point on the entire graph.
4. Can a function have an infinite absolute maximum value?
Yes, a function can have an infinite absolute maximum value. This occurs when the function continues to increase without bound and does not have a highest point on its graph.
5. Why is it important to find the absolute maximum value of a function?
Finding the absolute maximum value of a function can help us understand the behavior of the function and make predictions about its output. It is also useful in optimization problems, where we want to find the maximum or minimum value of a function within a certain range of input values.
