Where to purchase piezoelectrical components
  • Thread starter epicbattle
  • Tags
    Components
In summary, the actor is looking for a distributor who will sell high frequency piezoelectric ceramics in a small quantity. He is hoping that this frequency could be adjustable, and that this could help with an experiment he is working on.
epicbattle
Hello all,
I'm just trying to find a distributor that will sell high frequency piezoelectric ceramics in a small quantity. There are a ton of distributors, but they want purchases in bulk. I'm just a lowly stage actor who has an idea, and I want to figure out a way to test the relation between piezoelectrics and water. I don't know what I am looking for... I know that the frequency has to be about 2 Mhz... and if there is a way to adjust the frequency then that would be a plus.
This post is a shot in the dark. Any help or direction that can be given would be appreciated.
Here I made a quick sketchup of the way I want to setup the experiment. Maybe this will help with the kind of piezo device I need and where to better find it. The ones on Mouser and Allied were not the appropriate shape or frequency needed, but thank you.
http://img264.imageshack.us/img264/4746/piezosetuprl6.th.jpg
I looked for a while online for the same item (I was also curious about foggers/humidifiers/atomizers). The consensus seems to be that the easiest approach is to just buy a commercial humidifier and disassemble it.
I've used ultrasonic cleaners that have piezoelectric transducers mounted on the bottom of the tank. They can transfer energy to get the water hot enough to cause it to boil. But most are not running in the MHz range.
An ultrasonic cleaner, often colloquially referred to as a sonicator, is a cleaning device that uses ultrasound (usually from 15-400 kHz)
http://en.wikipedia.org/wiki/Ultrasonic_cleaning"
1. Where can I find piezoelectrical components for purchase?
There are several options for purchasing piezoelectrical components. You can try searching online through electronic component retailers, such as Digi-Key or Mouser. You can also check with local electronic stores or hardware stores that may carry these components. Additionally, you can contact manufacturers directly to purchase components in bulk.
2. What types of piezoelectrical components are available for purchase?
There are various types of piezoelectrical components available for purchase, including piezoelectric crystals, piezoelectric transducers, piezoelectric sensors, and piezoelectric actuators. These components are used in a variety of applications, such as in sensors, speakers, and motors.
3. How do I know which piezoelectrical component is right for my project?
The type of piezoelectrical component you need will depend on the specific requirements of your project. Consider factors such as size, voltage, frequency, and application when choosing a component. It is also helpful to consult with a specialist or do research to determine the best fit for your project.
4. How much do piezoelectrical components typically cost?
The cost of piezoelectrical components can vary depending on the type, size, and quantity needed. On average, you can expect to pay anywhere from a few dollars to a few hundred dollars for a single component. Purchasing in bulk can often save you money in the long run.
5. Are there any safety precautions I should be aware of when handling piezoelectrical components?
Yes, it is important to take proper safety precautions when handling piezoelectrical components. These components can generate high voltages, so it is important to handle them with care to avoid electric shocks. It is also important to follow proper wiring and installation procedures to ensure safe operation.
  • Materials and Chemical Engineering
  • Other Physics Topics
  • Mechanical Engineering
