Electric field caused by a uniform linear charge
In summary, The electric field caused by a uniform linear charge refers to the force per unit charge experienced by a test charge due to the presence of a uniformly charged object or line. It is calculated using the formula E = kλ/r and its direction depends on the position of the test charge. A positive electric field indicates a repulsive force while a negative electric field indicates an attractive force. The electric field can be shielded or cancelled by placing an oppositely charged object or line in close proximity.
gotem3303
29
A uniform linear charge density of [tex]\lambda[/tex] = 2.0 nC/m is distributed along the x-axis from x = 0 to x =3m. Which integral is correct for the magnitude of the electric field at x = -4 m on the x axis?
I'm going over a old test and he didn't circle the correct answer but I'm trying to understand the denominator.
I'm pretty sure I have everything but the denominator, would it be [tex]\int[/tex][tex]\frac{18dx}{(4+x)^{2}}[/tex] from 0 to 3?
Looks okay, except that you did not write any of the units.
Yes, that is the correct integral for the magnitude of the electric field at x = -4 m on the x-axis. The denominator represents the distance from the point where the electric field is being measured (x = -4 m) to the point where the linear charge density begins (x = 0). This distance is (4 + x), and since x = -4 m, the distance becomes (4 - 4) = 0. Therefore, the integral becomes \int\frac{18dx}{0^{2}} from 0 to 3, which is undefined. This makes sense since at x = -4 m, the point is located within the distribution of the linear charge density, so the electric field would be infinite.
1. What is an electric field caused by a uniform linear charge?
The electric field caused by a uniform linear charge refers to the force per unit charge experienced by a test charge placed at a particular point in space due to the presence of a uniformly charged object or line. It is a vector quantity and is represented by the symbol E.
2. How is the electric field calculated for a uniform linear charge?
The electric field is calculated using the formula E = kλ/r, where k is the Coulomb's constant, λ is the charge per unit length of the object or line, and r is the distance from the object or line to the point where the electric field is being measured.
3. How does the direction of the electric field depend on the position of the test charge?
The direction of the electric field depends on the position of the test charge in relation to the charged object or line. If the test charge is placed at a point closer to the charged object or line, the electric field will point away from the object or line, and if the test charge is placed at a point further away, the electric field will point towards the object or line.
4. What is the difference between a positive and negative electric field caused by a uniform linear charge?
A positive electric field indicates that the test charge will experience a repulsive force from the charged object or line, while a negative electric field indicates that the test charge will experience an attractive force towards the charged object or line.
5. Can the electric field caused by a uniform linear charge be shielded or cancelled?
Yes, the electric field can be shielded or cancelled by placing an oppositely charged object or line in close proximity to the charged object or line. This will result in the two electric fields cancelling each other out, resulting in no net electric field at the point between the two objects or lines.
