Integrating Current-Voltage Relationship for a Capacitor
In summary, to find the voltage-current relationship of a capacitor, the equation i = C(dv/dt) can be integrated to v = (1/C)(The Integral from -infinity to t) of i dt or v = (1/C)(The Integral from t0 to t) of i dt + v(t0). The integration from -infinity accounts for all previous currents and v(t0) is the integration constant representing the initial voltage on the capacitor.
vg19
67
To find the voltage-current relationship of a capcitor, integrate both sides of
i = C(dv/dt)
In the book they say, v = (1/C)(The Integral from -tve infitity to t) of i dt.
or
v = (1/C)(The Integral from tnot to t) of i dt + v(tnot)
I am trying to understand why they integrated from negative infinity. Why not start the integration at 0. I also do not undersstand in the second equation where the + v(tnot) came from.
Thanks in advance
An ideal capacitor will store all the charge that's ever applied to it. What you call 0 time is arbitrary (it could be a certain date and time, or when you start taking data, or anything else)--but the capacitor voltage also reflects currents that flowed before that time, all the way back.
BTW, the subscript is "nought" which means zero, not "not".
V_t0 is the integration constant (look back at your calculus book for an indefinite integral). The capacitor might have started with a voltage on it before it was hooked into your circuit.
I would approach this problem by first understanding the physical meaning of the equations and then analyzing the mathematics. The equation i = C(dv/dt) represents the relationship between the current and voltage in a capacitor, where C is the capacitance. This equation is known as the "charging equation" and it describes how the current changes with respect to time as the capacitor charges.
To find the voltage-current relationship, we need to integrate both sides of the equation. Integration is a mathematical operation that helps us find the total value of a quantity over a certain period of time. In this case, we are integrating the current with respect to time, which will give us the voltage.
Now, let's look at the first equation v = (1/C)(The Integral from -tve infitity to t) of i dt. The integral from -tve infitity to t represents the total value of the current from negative infinity to a certain time t. This means that we are considering the entire history of the current, starting from the moment the capacitor was connected to a voltage source. This is important because the voltage across a capacitor depends not only on the current at a given time, but also on the previous values of the current.
On the other hand, the second equation v = (1/C)(The Integral from tnot to t) of i dt + v(tnot) considers the current only from a certain initial time tnot to a later time t. This means that we are only looking at a specific time interval and not the entire history of the current. The term v(tnot) represents the initial voltage across the capacitor at time tnot.
So, to answer your question, we integrate from negative infinity to take into account the entire history of the current and its effect on the voltage across the capacitor. And the term v(tnot) is added to consider the initial voltage at a certain time tnot.
In summary, integrating the current-voltage relationship for a capacitor helps us understand how the voltage across the capacitor changes over time. By integrating from negative infinity, we take into account the entire history of the current, and the term v(tnot) accounts for the initial voltage at a certain time.
What is the current-voltage relationship for a capacitor?
The current-voltage relationship for a capacitor is a linear relationship, meaning that the current through a capacitor is directly proportional to the voltage across it. This relationship is described by the equation I = C(dV/dt), where I is the current, C is the capacitance, and dV/dt is the rate of change of voltage over time.
How is the current-voltage relationship for a capacitor integrated?
The current-voltage relationship for a capacitor can be integrated by using the equation Q = CV, where Q is the charge on the capacitor, C is the capacitance, and V is the voltage across the capacitor. This integration allows us to calculate the total charge stored on a capacitor at a given voltage.
What is the significance of integrating the current-voltage relationship for a capacitor?
Integrating the current-voltage relationship for a capacitor allows us to understand the behavior of capacitors in circuits and to calculate important parameters such as charge, voltage, and capacitance. It also allows us to analyze the time-dependent behavior of capacitors, such as how long it takes for a capacitor to charge or discharge.
What factors affect the current-voltage relationship for a capacitor?
The current-voltage relationship for a capacitor is affected by several factors, including the capacitance of the capacitor, the rate of change of voltage, and the type of material used to make the capacitor. Temperature and frequency of the applied voltage can also have an impact on the relationship.
How is the current-voltage relationship for a capacitor used in practical applications?
The current-voltage relationship for a capacitor is used in a variety of practical applications, such as energy storage in electronic devices, power factor correction in electrical systems, and filtering of signals in electronic circuits. It is also used in the design of capacitors for specific purposes, such as high voltage applications or high frequency circuits.
