External Hard Drive Pros & Cons: Buyer's Guide
In summary, I think it's a personal preference as to whether you go for an external or internal hard drive. Some people find them more portable and faster, while others find them more expensive and less space-efficient.
quasi426
208
I am thinking about getting an external hard drive, (just buying a harddrive and case). Can you guys give me some pros and cons of an external hard drive compared to an internal one.
Computer science news on Phys.org
Well if your "just buying a hard drive and a case", i assume you mean SCSI or SATA which is probably the same thing as getting an internal drive.
If you get an actual external hard drive, it'll be USB or Firewire. The disadvantages are that it is a bit slower and doesn't access as quickly, it also needs its own power cords :(. Pro: they are portable obviously, some have media readers installed on them... and well, they are huge chunks of memory you can take with you hehe.
I recommend Western Digital and Seagate. I've had my WD for 5 years now. And firewire is faster than USB 2.0 soo if you have both ports go for firewire.
I got this 250gb western digital media center ext. It is incredible...
... been using external Firewire drives for a couple of years as temp data storages, the latest for example Firewire 800 interfaces provide the necessary speed to utilize the drive capacities well, currently have one 500 Gb and one 1 Tb drive which occationally carry around. Been very satisfied with them.
Internal: Need room in your computer. If you have an open drive bay, free power connector and IDE/SATA/SCSI port free in your computer, you're fine.
External: Need space on your desk, a free SCSI, USB or IEEE-1394 (Firewire) port and an open outlet on your power bar. Only a little bit slower if it's attached to a USB 2 port (a lot slower if it's only on a USB 1 port), but usually not significantly noticable.
Desk space for me is usually at a premium, so my first choice is to go for internal drives.
I think price is to be considered. Internal hard drives are considerably cheaper (with more storage space). I've looked at the 1Tb external hardrives but last time i checked they were going at about $900, i guess it depends on what your needs are.
Oh yah, price/space is a big difference as well. I've seen 2.5gb/$1 internal 7200rpm sata drives while I am probably only getting 1.5gb/$1 7200 external at the most (as of about 6 months ago).
Related to External Hard Drive Pros & Cons: Buyer's Guide
1. What are the advantages of using an external hard drive?
There are several advantages to using an external hard drive, including increased storage space, portability, and the ability to easily transfer files between devices. They also provide a backup for important data and can be used to free up space on your computer's internal hard drive.
2. Are there any disadvantages to using an external hard drive?
One potential disadvantage of using an external hard drive is the risk of physical damage, which can lead to data loss. They also require additional cables and connections, which can be inconvenient. Additionally, external hard drives may be more expensive than internal hard drives.
3. Can an external hard drive be used as a primary storage device?
While external hard drives can be used to store large amounts of data, they are not typically recommended as a primary storage device. This is because they are generally slower than internal hard drives and can be more prone to physical damage.
4. What is the best type of external hard drive for my needs?
The best type of external hard drive for you will depend on your specific needs. Some factors to consider include storage capacity, data transfer speed, and durability. It is also important to ensure compatibility with your devices and to choose a reputable brand for reliable performance.
5. Can I use an external hard drive to store and access my files from multiple devices?
Yes, external hard drives can be used to store and access files from multiple devices, as long as they are compatible with each device's operating system. However, it is important to properly eject the hard drive before disconnecting it to avoid potential data loss or corruption.
  • Computing and Technology
