Understanding Uncertainty in Measuring Cylinder Volume: A Scientific Exploration
  • Thread starter twoflower
Sorry!In summary, the conversation discusses the maximum flaw in measuring the volume of a cylinder using the given formula and values. The formula for volume is V = πr²h and the given values are v = 5 cm (with a precision of 0.005 cm) and r = 3 cm (with a precision of 0.01 cm). The maximum error in measuring the volume is calculated using the derivative and partial derivative of the formula, giving an approximate error of 0.345π cm³. This is further explained using the concept of total differential and the relationship between the variables r and h. The conversation ends with a thank you to the contributors for providing a
twoflower
368
Hi,
we were given this problem in the class:
Volume of cylinder is [itex] V = \pi r^2h[/itex]
v = 5 cm (with precision of 0.005 cm)
r = 3 cm (with precision of 0.01 cm)
What maximum flaw was the volume of the cylinder measured with?
Well, I didn't know how to do it, so I just wrote teacher's solution. Now I'm trying to understand it, but without success. Here it is:
[tex]
h = 5 cm,\ dh = 0.0005\ cm
[/tex]
[tex]
r = 3 cm,\ dr = 0.01\ cm
[/tex]
[tex]
dV =\ ?
[/tex]
[tex]
dV = \frac{\partial V}{\partial h} dh\ +\ \frac{\partial V}{\partial r}dr = \pi r^2 dh\ +\ 2\pi rh dr\ =\ 0.345\ \pi cm^3
[/tex]I just don't get the idea at all...Could someone explain it to me?
Thank you.
Recall that the derivative, [itex]\frac{dy}{dx}[/itex] is the limit of the "difference quotient", [itex]\frac{y(x+h)- y(x)}{h}[/itex], as h goes to 0. If h is small, then [itex]\frac{dy}{dx}[/itex] is approximately equal to the difference quotient. Of course, then, y(x+h)- y(x) is approximately equal to [itex]\frac{dy}{dx}h[/itex]. Often we write that as if h were equal to "dx": [itex]\frac{dy}{dx}dx= dy[/itex]. That's not true but as long as h is small, it is approximately correct.
Now, suppose y= y(x) is a function of x and, in measuring x, we make a slight error and get x+h. Calculating y with that incorrect value of x we get y(x+h) when the true value should be y(x). The error is y(x+h)- y(x) which, as above, is approximately dy= y'(x)dx. That is, although technically dx and dy only have meaning in the derivative, we can approximate dx by the "error in x" and dy by the "error in y".
Here, [itex]V= \pi r^2h[/itex] and so, as you have,
[tex]dV= 2\pi rh dr+ \pi r^2 dh[/itex]
Now we approximate dr by the error in r: dr= 0.005 and dh by the error in h: dh= 0.01. setting r= 3 and h= 5 gives the result you state.
Again, that is approximate. One can calculate the exact value by:
Since h was measured as 5cm and the maximum error in h is 0.005 cm, h could be as large as 5.005 cm. Since r was measured as 3 cm and the maximum error in r is 0.01, r could be as large as 3.01 cm. That means that the volume of the cylinder could be as large as [itex]\pi (3.01^2)(5.005)= 142.458[/itex].
On the other hand, h could be as small as 5-0.005= 4.995 and r could be as small as 3-0.01= 2.99. That means that the volume of the cylnder could be as small as [itex]\pi(2.99^2)(4.995)[/itex]=140.290.
Since [itex]\pi(3^2)(5)= 141.371[/itex] you can see that [itex]142.458-141.371= 1.087[/itex] and [itex]141.371- 140.290= 1.081[/itex] so that the "possible error" of [itex]0.345\pi[/itex] = 1.0838 from the approximation is correct to 2 decimal places.
The last line in HallsofIvy's post above with the non-displayed latex graphic is:
"Since [itex]\pi(3^2)(5)= 141.371[/itex] you can see that 142.458-141.371= 1.087 and 141.371- 140.290= 1.081 so that the "possible error" of [itex]0.345\pi=1.0838[/itex] from the approximation is correct to 2 decimal places."
Thanks, benorin, I've fixed it. I left out a [/itex]!
Thank you HallsoftIvy for your comprehensive explanation, now I get it, excepting this step:
If V were function of single variable, I would write
[tex]
dV = V'(x)\ dx
[/tex]
But there are two variables..
I see that the expression is equal to:
[tex]
dV = \frac{\partial V}{\partial r}\ dr + \frac{\partial V}{\partial h}\ dh
[/tex]
Anyway, I don't know why. Is it some use of chain rule? Or something different?
Thank you.
[tex]
[/tex]
It's not the chain rule. The chain rule is a theorem. What you have cited above is the definition of the total differential of a function of two variables.
Well, probably you're right, we didn't any definition involving this expression for total differential.
Anyway, total differential is always in some particular point, isn't it? (I mean the linear transformation, not the value in some point itself)
We had defined total differential as linear transformation which satisfies certain zero limit.
Then after few theorems it was clear that in point h the value of total differential of function f in point a is equal to
[tex]
Df(a)(h) = \bigtriangledown f(a) .h
[/tex]
where
[tex]
\bigtriangledown f(a) := \left(\frac{\partial f}{\partial x_1}(a), ... , \frac{\partial f}{\partial x_n}(a)\right)
[/tex]
Could you please show me the connection?
Thank you.
Sure, the 2 dimensional analog of your equation [itex]dV(x)=V'(x)dx[/itex] is:
[tex]dV(x,y)=\vec{\nabla}V(x,y)\cdot d\vec{r}[/tex],
where [itex]d\vec{r}=dx\hat{i}+dy\hat{j}[/itex].
This gives us:
[tex]dV(x,y)=\frac{\partial V}{\partial x}dx+\frac{\partial V}{\partial y}dy[/tex]
Now let [itex]x=r[/itex] and [itex]y=h[/itex] and you've got it.
[tex]dV(x,y)=\vec{\nabla}\cdot d\vec{r}[/tex],
This gives us:
Thank you Tom! I had little problems with the way of symbolics used, but now I have it and I'm happy. I hate solving problems just with learned approach but not understanding the idea.
Thank you all, HallsoftIvy, Tom, benorin!
Just a heads up: I had a typo in my post, which I have just corrected.
This:
should have been this:
This:
Yes, that's what I was referring to when I wrote "I had little problems with the way of symbolics used" :smile:
1. Where did this come from?
This question is often asked in reference to a specific object or concept. The answer depends on the context, but in general, everything in the universe can be traced back to the Big Bang. This is the scientific explanation for the origin of our universe.
2. What is the origin of life on Earth?
The origin of life on Earth is still a topic of debate among scientists. However, the most widely accepted theory is that life on Earth originated from simple organic molecules that formed in the primordial soup of early Earth's oceans. Over time, these molecules evolved into more complex organisms through the process of natural selection.
3. How did humans evolve?
Humans evolved through a process called natural selection, which was first proposed by Charles Darwin. This process involves the gradual change of a species over time through genetic mutations and the selection of the most advantageous traits. The exact timeline and mechanisms of human evolution are still being studied by scientists.
4. What is the origin of the universe?
The origin of the universe is believed to be the Big Bang, a massive explosion that occurred approximately 13.8 billion years ago. This event marked the beginning of the universe and the rapid expansion of matter and energy. The exact cause of the Big Bang is still unknown and is an area of ongoing research in the field of cosmology.
5. Where did the elements come from?
The elements that make up our world were formed through a process called nucleosynthesis. This occurred during the early stages of the universe, as stars formed and fused together lighter elements to create heavier ones. When these stars exploded, they released these elements into the universe, and they eventually formed into planets, including Earth.
