Finding Maximum Deflection of Bending Curve
In summary, you can find the maximum bending moment by plotting the deflection line/curve and observing that the moment of maximum deflection occurs at x=\frac{l}{2}.
teng125
416
if i have a bending curve eqn of w'(x) = (q/6)<x-l>^3 - ql/4 <x-0>^3 - 3ql/4 <x-l>^2 + (9ql^3)/24
suppose to find the deflection of maximum of the beam, we have to set w'(0)=0 .Am i right??
then if it is right,how can i find the value for x on which the max bending occur because i don't know how to factorize the heaviside function such as <x-l>^3
anybody pls help
thanx
if [itex] \nu [/itex] represents the deflection function then
[tex] \nu (x) = f(x) [/tex]
therefore by using you knowledge on differential calculus, in order to look for a max or min you must differentiate [itex] \nu (x) [/itex] (coincidentially the rotational angle or slope) and set it to 0, find the x and substitute in your deflection function. This is the way for the integration of the deflection differential equation.
ya,that's exactly what i stated above.But,i don't know how to find x as ican't find a way to factorize
pls show me
thanx
In the attachment above I stated that it is not necessary to find the x and I stated the reasons and also an alternative to solve it. Didn't you read it, teng125?
the link is invalid
All right then, I rewrite it here.
I have corrected your original bending curve by inserting the factor of 1/EI where EI is the bending stiffness of the beam I assumed.
[tex]w'(x)=\frac{1}{EI}[\frac{q_{0}}{6}(x-l)^3-\frac{q_{0}l}{4}(x-l)^3-\frac{3q_{0}l}{4}(x-l)^2+\frac{9q_{0}l^3}{24}][/tex]
To find the position along the beam at which the deflection is maximum, w' (x) = 0, NOT w' (0) = 0.
Hence, expanding the unitstep or heaviside functions as if they were normal polynomial functions gives
[tex]= \frac{1}{EI}[\frac{q_{0}{6}(x^3-l^3+2l^2x-2lx^2)-\frac{q_{0}l}{4}(x^3\mbox{...})\mbox{...}[/tex]
[tex]=\mbox{...}[/tex]
As you can imagine, it is very complicated. I doubt you would have time solving for x in the examination.
However, you can predict the position along the beam at which the deflection is maximum by observing the moment diagram M(x). Just look at the stationary point(s) and the corresponding position x yields the maximum deflection.
Anyway, our professor has told us that this kind of problem will not be asked in the examination. If it were asked, you just need to write
[tex]w'(x)=\frac{1}{EI}[\frac{q_{0}}{6}(x-l)^3-\frac{q_{0}l}{4}(x-l)^3-\frac{3q_{0}l}{4}(x-l)^2+\frac{9q_{0}l^3}{24}]=0[/tex]
solving for x gives the position along the beam at which maximum deflection occurs.
for the examination is to test your knowledge and skills in mechanics, not elementary pure mathematics (leave this task to the mathematicians).
some of the latex appears to be incorrect, they refuse show what I wanted to display.
okok...thanx very much...besides,do u know any websites or materials that shows or teach students how to draw bending moment diagrams for the chapter above??
Refer to your lecture or exercise notes perhaps? If you have time, you can make a small table listing all the key points. For example:
Code:
   x	| V(X)	|  M(x)	|
   l	| 1/2ql	| ql^2	|
  2l	| ... 	| ...	|
 3/2l   | ...	| ...	|
By identifying the nature of the functions within each segment ((1/2)l, l, 2l etc), that is to check if they are linear, quadratic or cubic, then plot the curve. Of course, you will have to know the basic shape of the curves of each type of function.
for the basic shape of the curves of each type of function, do u have any materials for them??or any recommended websites??
thanx
I hope that you were joking. You know the linear (a line), quadratic curves and cubic curves, don't you?
Anyway, I have prepared the shear and bending moment diagrams for the present problem. As you expected, they are piecewise-connected functions due to the fact that you have defined them using unitstep/singularity/heaviside functions.
Shear Force, V(x)
Bending Moment, M(x)
Note that the y-axis of the moment diagram is reflected about the x-axis by convention. Now you see that the maximum bending moment occurs at [tex]x=\frac{l}{2}[/tex]. Hence, inserting this value of [tex]x[/tex] into the deflection line/curve above yields the maximum deflection.
1. What is the maximum deflection of a bending curve?
The maximum deflection of a bending curve refers to the maximum displacement or deformation that a beam or structure experiences when subjected to an external load. It is typically measured in units of length, such as inches or millimeters.
2. How is the maximum deflection of a bending curve calculated?
The maximum deflection of a bending curve can be calculated using a mathematical formula that takes into account the properties of the beam or structure, the magnitude and distribution of the external load, and the supports and constraints of the beam or structure.
3. What factors affect the maximum deflection of a bending curve?
The maximum deflection of a bending curve is affected by several factors, including the material properties of the beam or structure, the magnitude and distribution of the external load, the shape and dimensions of the beam or structure, and the supports and constraints of the beam or structure.
4. Why is it important to determine the maximum deflection of a bending curve?
Determining the maximum deflection of a bending curve is important because it helps engineers and designers ensure that a structure or beam can withstand the expected loads and will not experience excessive deflection or deformation that could lead to failure.
5. How can the maximum deflection of a bending curve be minimized?
The maximum deflection of a bending curve can be minimized by using stronger or stiffer materials, changing the dimensions or shape of the beam or structure, or adding additional supports or constraints. It is important to consider all of these factors during the design process to achieve a structure with minimal deflection.
