| Thread Closed |
positive charge distributed uniformly along y axis |
Share Thread | Thread Tools |
| Aug28-06, 09:29 PM | #1 |
I have a physics question that states:
An amount of positive charge is distributed uniformly along the positive y-axis between y=o and y=a. A negative point charge -q lies on teh positive x=axis a distance r from the origin. Derive the x and y compontes of the force that the charge distribution exerts on Q exerts on q. I have figured the y force to be: (Qqk/a)[(q/x)-(1/(a^2 +x^2)^1/2)] I did this by drawing out the graph and by doing an intgral from 0 to a on dfsin theta. Where theta is the angle where the line comes from the top of through q. I then used trig substitution to figure out what sin theta is. The part that I am stuck on is how do I solve for the force on the X axis. Any help is much appreciated. |
| Aug29-06, 07:45 AM | #2 |
Recognitions:
[tex]F = \frac{kq}{(r^2+y^2)}dQ = \frac{kqQ}{a(r^2+y^2)}dy[/tex] So the components of the Coulomb force on q would be: [tex]F_x = \frac{kqQ}{a}\int_0^a \frac{1}{y^2+r^2}cos\theta dy[/tex] [tex]F_y = \frac{kqQ}{a}\int_0^a \frac{1}{y^2+r^2}sin\theta dy[/tex] where [itex]sin\theta = y/\sqrt{y^2+r^2}[/itex] and [itex]cos\theta = r/\sqrt{y^2+r^2}[/itex] Work out those integrals and you should get the right answer. AM |
| Thread Closed |
| Thread Tools | |
Similar Threads for: positive charge distributed uniformly along y axis
| angles from the positive x-axis | Introductory Physics Homework | 4 | ||
| Positive direction of the X axis? | Introductory Physics Homework | 6 | ||
| Electric field of a uniformly distributed rod | Introductory Physics Homework | 2 | ||
| Uniform Distributed Electric Charge | Introductory Physics Homework | 11 | ||
| Attraction between positive charge and negative charge | Atomic, Solid State, Comp. Physics | 6 | ||
