| Thread Closed |
Projectile Motion Problem |
Share Thread | Thread Tools |
| Sep27-06, 04:57 PM | #1 |
8. A Physics student on Planet Exidor throws a ball, and it follows the parabolic trajectory shown in Figure 6.8 (whille it will not be recreated on this forum, the figure shows a part of a parabolic curve which starts at the origin and peaks at t=2. It also shows the velocity vector at t=1, which will be entered later in the pst). The ball's position is shown at 1 s intervals until t=3s. At t=1 s, the ball's velocity is (2.0i + 2.0j)m/s, where i and j are unit vectors.
a. determine the ball's velocity at t=0,2,and 3 s. b. what is the value of g on planet Exidor? c. what was the ball's launch angle. I know how to do parts b and c, but can't do either without a. I'm not sure what formula to use, but I do know the following: at t=1: v1=(2.0i + 2.0j)m/s v1x=2.0im/s v1y=2.0jm/s ax=0 ay=-g m/s^2 v1x=v0x=v2x=v3x2.0im/s x0=0m y0=0m Thank you in advance. |
| Sep27-06, 05:04 PM | #2 |
Mentor
Treat the vertical and horizontal components separately. Hints: What's the vertical component of velocity at the highest point? (t = 2) What about the horizontal component?
| Sep27-06, 05:21 PM | #3 |
Figured it out. since the velocity in the y direction is 0m/s at t=2s, I was able to calculate the gravity. I then used this to find the velocities at the other times. I don't know if using part b to solve part a is correct, but I can check my instructor's webpage to see if it gets the correct answer.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Projectile Motion Problem
| Projectile Motion Problem | Introductory Physics Homework | 3 | ||
| Projectile Motion Problem | Introductory Physics Homework | 4 | ||
| Projectile Motion + Linear Motion = Problem | Introductory Physics Homework | 3 | ||
| Uniform Circualr Motion with Projectile Motion problem (Extremely confusing): | Introductory Physics Homework | 4 | ||
