Pressure Vessels: Radial & Hoop Stresses at Inner & Outer Surfaces
  • Thread starter Thread starter tone999
    Pressure
The discussion focuses on calculating radial and hoop stresses for a cylinder with an internal diameter of 30mm and an external diameter of 50mm, subjected to an internal pressure of 60MPa. The relevant equations presented are for radial stress and hoop stress, which involve the internal radius (r1) and external radius (r2). The values for r1 and r2 are confirmed as 0.015m and 0.025m, respectively. The participants emphasize the importance of consistent units, particularly converting pressures to the appropriate metric system.
  • Understanding of radial and hoop stress calculations
  • Familiarity with pressure vessel design principles
  • Knowledge of unit conversions in engineering (e.g., MPa to N/m²)
  • Basic proficiency in using stress formulas for cylindrical structures
  • Study the derivation of radial and hoop stress equations in cylindrical coordinates
  • Learn about the application of the thin-walled cylinder assumption in pressure vessel design
  • Explore the effects of material properties on stress distribution in pressure vessels
  • Investigate software tools for stress analysis in engineering, such as ANSYS or SolidWorks
Mechanical engineers, structural analysts, and students studying pressure vessel design and stress analysis will benefit from this discussion.
tone999
A cylinder has an internal diameter of 30mm and an external diameter of 50mm and is subject to an internal pressure which is 60MPa above that in the air surrounding the cylinder. Determine the radial and hoop stresses at the inner and outer surfaces.
Basically i know:
internal radius in know as r1
external radius is r2
radial stress: pr1 squared/r2squared-r1squared X (r squared - r2 squared/ r squared)
hoop stresses : pr1 squared/r2squared-r1squared X (r squared + r2 squared/ r squared)
I don't know if these two equations are correct hopefully somebody could clarify this for me because the working out should be simple when this is known.
I don't know what "r" is?
If i knew that i could take a stab at the equations hopefully somebody could give me two answers and if the equations are correct and two answers and i will do it myself to check this. Thanks
Radius is half the diameter, which would be 15mm and 25mm. I don't know if your formula is correct but make sure you keep the units consistent; I think MPa requires that you work in meters (m), not milimeters (mm).
Yeah I've got that. I mean "r" on its own in the equation. I know the values for r1 - 0.015m
r2 - 0.025m
Internal pressure - 60x10 to the power of 6 Nm2
  • · Replies 61 ·
14K
  • · Replies 16 ·
