Transformation Of Probability Density Functions
The discussion focuses on finding the probability density function (pdf) for the sum of two independent random variables, X and Y, with given pdfs f_X(x)=2(1-x) and f_Y(y)=2(1-y) defined on the interval [0,1]. The user initially attempts to derive the cumulative distribution function (cdf) F_Z(z) and subsequently the pdf f_Z(z) through integration but encounters issues with the integral yielding zero. The correct approach involves splitting the problem into cases based on the value of z, specifically for intervals z<0, 02, to accurately compute the area of integration.
  • Understanding of probability density functions (pdfs)
  • Knowledge of cumulative distribution functions (cdf)
  • Familiarity with double integrals in calculus
  • Concept of independent random variables
  • Study the concept of convolution of probability distributions
  • Learn about the properties of independent random variables
  • Explore the use of Mathematica for symbolic integration
  • Investigate the geometric interpretation of probability distributions
Students and professionals in statistics, data science, or mathematics who are working with probability distributions and require a deeper understanding of the transformation of probability density functions.
caffeine
Let X and Y be random variables. The pdfs are [itex]f_X(x)=2(1-x)[/itex] and [itex]f_Y(y) = 2(1-y)[/itex]. Both distributions are defined on [0,1].
Let Z = X + Y. Find the pdf for Z, [itex]f_Z(z)[/itex].
I'm using ideas, not equations.
I'm dying of curiosity about where I'm going wrong. I'm so sure of each step, but my answer can't be correct because [itex]\int_0^2 f_Z(z)\,dz[/itex] is zero! Here's my logic.
Consider the cdf (cumulative distribution function) for Z:
[tex] F_Z(z) = P(Z\le z) = P(X+Y \le z)[/tex]
Here, [itex]F_Z(z)[/itex] is the volume above the triangle shown in the image I attached to this message (in case something happens to the attachment, it's the triangle in quadrant 1 bounded by x=0, y=0 and x+y=z.)
The volume above the shaded region represents [itex]F_Z(z)[/itex].
[tex] F_Z(z) = \int_{x=0}^{x=z} 2(1-x)\int_{y=0}^{y=z-x} 2(1-y)\,dy\,dx[/tex]
Performing the integrals gives [itex]F_Z(z) = \frac{1}{6}z^4 - \frac{4}{3}z^3 + 2z^2[/itex]. Then taking the derivative of the cdf gives the pdf:
[tex] f_Z(z) = \partial_z F_Z(z) = \frac{2}{3}z^3 - 4z^2 +4z[/tex]
Unfortunately, this can't be right because the integral of this function over [0,2] gives zero.
I also would've expected that the maximum of [itex]f_Z(z)[/itex] would be at z=0 since individually, X and Y are most likely to be zero.
I checked my algebra and calculus with Mathematica; it looked fine. I think there's a conceptual problem. There must be something I don't understand or some point I'm not clear about.
What did I do wrong?
You have to split the problem into different cases.
i) z<0
ii) z<1
iii) 1<z<2
iv) z>2
In each case the area of integration is different. But for each case, your model for the integral is
[tex]F_Z(z)=\int\int_{\{(x,y)\in [0,1]\times[0,1]:\ y\leq z-x, \}}f_{XY}(x,y)dxdy[/tex]
So you're integrating over the area that's the intersection of the square [0,1] x [0,1] with the area under the curve y=z-x.(Btw, you never said that X and Y are independent but I assume they are?)
Ahhh... yes. I *completely* understand.
We're integrating that portion of the unit square (in QI with lower left corner at origin) that lies underneath x+y=1.
So when 0<z<1, there's only one function that represents the "top": the line x+y=z.
And when 1<z<2, there's two functions: y=1 and x+y=z, and therefore we need to break the region of integration into two portions.
Got it. Thanks.
And, yes. :-)
  • · Replies 19 ·
