Thread Closed
Perfect square
Share Thread Thread Tools
Feb5-07, 07:29 AM   #1
Cool
Perfect square
[tex]\left(\frac{\dot{x}}{a}\right)^2 = K\left[b\frac{a}{x} + c\left(\frac{a}{x}\right)^2 + (1-b-c)\right][/tex]
Show that, for [itex]b<1[/itex], there is a value of [itex]c[/itex] that makes the right hand side a perfect square of a function of x.
2. The attempt at a solution
I guess that a perfect square is a square of a function that can be written as
[tex](x \pm d)^2 = x^2 \pm 2xd + d^2[/tex]
but I have not been successful in this problem.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb5-07, 08:30 AM   #2
Math 2012
Recognitions:
That's the right general idea, but for your equation you want something like ((a/x) + d)^2.
If you have an expression like ax^2 + bx + c and it is a perfect square, what is special about the two roots of the quadratic equation ax^2 + bx + c = 0? What condition can you use to decide what kind of roots a quadratic equation has?
Feb5-07, 08:41 AM   #3
If [itex]ax^2+bx+c[/itex] is a perfect square, then [itex]b=2 \sqrt{ac}[/itex] and the roots of [itex]ax^2+bx+c=0[/itex] is a double root [itex]x_{1,2}=-\sqrt{c/a}[/itex]. I'm not sure what you mean with the conditions..
Feb5-07, 09:35 AM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Perfect square
First let u= a/x. Now, what value of c makes cu2+ bu+ 1-b-c a perfect square? Also recall that Ax2+Bx+ C is a perfect square if and only if B2-4AC= 0. However, it seems to me that b would have to be less than or equal to 1/2 for this to be true, not just less than 1.
Feb5-07, 09:39 AM   #5
and if [itex]b^2=4ac[/itex] then [itex]ax^2+bx+c[/itex] is a perfect square. So you know the condition already.
Look again at your quadratic (shame it uses the same letters as those in the general form of the quadratic you have given)
In your quadratic what is equivalent to 'x' 'a', 'b', 'c' in the general form?
Feb5-07, 10:07 AM   #6
Quote by HallsofIvy View Post
Then
[tex]c = \frac{b-1 \pm \sqrt{1-2b}}{2}[/tex]
but that's two values. I think I also want to have [itex]-1 \leq c \leq 1[/itex] for my problem.
Feb6-07, 04:31 AM   #7
Ok, this is correct. But now I need to find an exact solution for [itex]x(t)[/itex] in this case. Help..? =)
Feb6-07, 05:19 AM   #8
Recognitions:
Now write that right hand side as a perfect square, take the square root of both sides and solve the resulting separable differential equation.
Feb6-07, 06:34 AM   #9
Then I get, using [itex]u=a/x[/itex],
[tex]u=\sqrt{\frac{1-b-c}{c}} \left[ \frac{(exp[K(1-b-c)^{1/4}t]+1)^2}{(exp[K(1-b-c)^{1/4}t]-1)^2} - 1 \right][/tex]
and when I then try to solve for x and show that this is a solution I get these infinite calculations so this doesn't seem right.
Thread Closed
Thread Tools
Similar Threads for: Perfect square
Thread Forum Replies
Perfect square Precalculus Mathematics Homework 3
show that n+2 is not a perfect square Calculus & Beyond Homework 7
perfect square Calculus & Beyond Homework 11
perfect square Linear & Abstract Algebra 10
perfect square??? Linear & Abstract Algebra 2
