Are F5[x]/(x^2 + 2) and F5[x]/(x^2 +3) Isomorphic Polynomial Rings?
  • Context: Graduate
  • Thread starter Thread starter catcherintherye
    Polynomial Rings
The discussion revolves around the isomorphism between the polynomial rings F5[x]/(x^2 + 2) and F5[x]/(x^2 + 3). Participants explore various approaches to demonstrate this isomorphism, including hints about modular arithmetic and ring homomorphisms.
  • One participant seeks hints on how to show that F5[x]/(x^2 + 2) and F5[x]/(x^2 + 3) are isomorphic.
  • Another participant suggests that since 3 is congruent to -2 modulo 5, this may be relevant to the isomorphism.
  • A participant proposes showing that both fields are isomorphic to a group and concluding their isomorphism from that perspective.
  • One reply clarifies that the task is to show isomorphism as polynomial rings, not merely as groups, and emphasizes the need to write down the isomorphism explicitly.
  • Hints are provided regarding the dimensions of the rings and the structure of a potential homomorphism.
  • Confusion arises regarding the application of hints and the nature of the homomorphism being constructed.
  • Participants discuss the implications of the orders of elements and the necessity of ensuring that the proposed maps maintain the properties of ring homomorphisms.
  • One participant explains that the two rings can be viewed as isomorphic to F5[a] and F5[b], where specific relationships between a and b are highlighted.
  • Another participant reiterates the importance of finding a suitable map to demonstrate the isomorphism between the quotient rings.
Participants express differing views on the appropriate methods to demonstrate the isomorphism, with no consensus reached on a single approach. Some participants emphasize the need for explicit ring homomorphisms, while others suggest alternative methods involving group isomorphisms.
Participants reference modular arithmetic and the properties of polynomial rings, but there are unresolved aspects regarding the specific mappings and the implications of the hints provided. The discussion reflects varying levels of understanding about ring homomorphisms and their application in this context.
catcherintherye
I am required to show that F5[x]/(xsqd + 2) and F5[x]/(xsqd +3) are isomorphic, any hints on how to go about this question?
Hint: 3=-2 mod 5. I can give a second hint later if need be
okay, so i have done similar questions where i show e.g F5[x]/xsqd+3x+3 isomorphic to C24 would it be an appropriate course of solution to attempt to show that both of the above fields were isomorphic to a group and then conclude isomorphic to each other?
No. You're asked to show they are isomorphic as polynomial rings. That means more than just isomorphic as groups (under what operation?). So your previous example is not correct, unless you want to cite some big result to do with fields or something. You can do this by just writing down the isomorphism. Hint, again: 3=-2 mod 5.
EG. Why is Z[x]/x^2 isomorphic as a ring to Z[x]/(x-2)^2? Just send x to x-2.
also I've been given as a hint that 'both dim=2 over F3 basis 1,x H=(aij)
elements of matrix a11=1, a12=b, a21=0, a22=a
that we must have 1=1 and i am to check H(xy)=H(x)H(y) so x=ax + b
but i am still confused!
What's confusing? You're writing it as a vector space, and writing down a map. You're asked to show it is a ring homomorphism too. It wouldn't be the way I'd do it (though it is equivalent).If you know these are fields, it suffices to count elements. If you don't then you need to write down a ring homomorphism, so you need to get your hands dirty and do it. Any ring map sends 1 to 1, and must send x to ax+b for some choice of a and b. So figure out what, if any, choices of a and b mean this is an isomorphism.
There are only two things to remember: 2=-3 mod 5 (why do I keep writing that I wonder...) and 4=-1 mod 5 (that is the second hint).
i don't get it I've got order x=ordery=8 and so defined a homomorphism H(x)=y and it seems to give a perfectly good isomorphism, so where do all these hints and stuff come in?
What is x, what is y? So what that the order of x and y are the same? What do you mean by order? I will guess that you mean the map from
F_5[x]/(x^2+2) ---> F_5[y]/(y^2+3)
sending x to y is an isomorphism. This I doubt. For instance this map sends x^2+3 to 0, and x^2+3 is not zero in F_5[x]/(x^2+2). It is in fact equal to 1, so your map sens 1 to 0.
Let me explain the hint. The two rings are isomorphic to F_5[a] and F_5 where a^2=3=-2 and b^2=2. Notice that -1 is square mod 5 so multipliying a by a square root of -1 is an isomorphism (it is an invertible ring homomorphism). This corresponds to multiplying x by the square root of -1 in the polynomial ring case.
to show rings are isomorphic, find a map from one to the other,a nd then show it is an isomorphism.
a ring map from a quotient ring to another ring i a ring map from th top tht sends to bottom to zero.
i.e. A map R[X]-->S induces one from R[X]/(f)-->S if it sends X to a root of f . that should do it.
  • · Replies 24 ·
  • · Replies 21 ·
  • · Replies 0 ·
