| Thread Closed |
drawing a simple vector field issue |
Share Thread | Thread Tools |
| Mar22-07, 12:01 PM | #1 |
Hello everyone i'm not sure if this is right or not...
If i have F(x,y,z) = zj; where j is the vector, j hat. Would that be all vectors are going to be pointing up if you assume z is up, and are in the y plane? If the coordinate sytem is, z is up, y is to the right, and x is pointing at you. If i had F(x,y,z) = yj; the answer is, No vectors emanate from the xz plane since y = 0 there. In each plane y = b, all the vectors are identical. |
| Mar22-07, 12:44 PM | #2 |
Recognitions:
No. j is a unit vector pointing in the same direction as the +y axis. Which you seem to want to call 'right'. The length of the vectors is proportional to their z coordinate. What is the 'y plane'? What does 'in' a plane mean? Parallel to?
| Mar22-07, 12:53 PM | #3 |
I worked it out and it seems the vectors are pointing parrallel to the +y axis which is pointing right, for values > 0, and for values < 0 its pointing to the left or in the -y direction.
| Mar22-07, 12:57 PM | #4 |
Recognitions:
| Mar22-07, 01:52 PM | #5 |
z is a number, j is a vector pointing in the positive y direction. Your vector field consists of vector pointing in the positive y direction, longer as z increases. (And pointing in the negative y direction for z negative.)
| Thread Closed |
| Thread Tools | |
Similar Threads for: drawing a simple vector field issue
| Electric Field Vector Drawing | Introductory Physics Homework | 2 | ||
| Looking for vector drawing program. | Introductory Physics Homework | 1 | ||
| A simple molecular drawing program? | Chemistry | 5 | ||
| I need simple drawing software! | General Math | 14 | ||
| Terminology Question (drawing a vector triangle) | Introductory Physics Homework | 2 | ||
