Thread Closed
Simple Calculus Word Problem (using derivatives to anaylze function models)
Share Thread Thread Tools
Feb27-08, 09:42 PM   #1
Hello, new here, first post. Just need some help with homework.
Question One
This norman window is made up of a semicircle and a rectangle. The total perimeter of the window is 16 cm. What is the maximum area?
* * <<< Semicircle
| | <<< Rectangle
L | |
______
D
2. Relevant equations
P (total) = 2L + D + (pi * d)
A (total) = D * L + (pi(d/2)^2)/2)
3. The attempt at a solution
What I did was using this equation:
16 = 2L + D + ((pi * d)/2)
L = 8 - d/2 - ((pi * d)/4)
A = D (8 - d/2 - ((pi * d)/4)) + (pi (d/2)^2)/2)
A = 8d - (d^2)/2
A' = 8 - d
Let 0 = A' to find critical value
then 8 = d.
When I sub that back into the original equation, I get L as a value less than 8, which doesn't make sense. (I think it works out to be L = 4 - pi)
I'm pretty much lost, sorry if this is too messy to read, any help would be appreciated. Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb27-08, 10:55 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
You made a great start. But where did you get "16 = 2L + D + ((pi * d)/2)"?? The "/2" wasn't in your original expression for P. You are just making algebraic mistakes.
Feb27-08, 11:05 PM   #3
I think you're doing fine up until this point:
Which should simplify into
[tex]
A = 8*D - \frac{D^2}{2} - \frac{pi*D^2}{4} + \frac{pi*D^2}{8}
[/tex]
You would then go on to take the derivate and then set it to zero and solve for your D value
I've been beaten =(
Feb27-08, 11:31 PM   #4
Quote by Dick View Post
ah sorry, its actually supposed to be "/2", that way its half the area, sorry the drawing didnt show up. its supposed to be a semi-circle connected to a rectangle.
Quote by RyanSchw View Post
[tex]
[/tex]
I've been beaten =(
sorry, that was a typing error as well haha.
A = L * D + (pi*d)/2
which becomes
A = 8 - d/2 - ((pi * d)/4)
this still doesnt work...I think i'm using the wrong equations somehow
Feb27-08, 11:43 PM   #5
Recognitions:
Why isn't there a D in all of the terms of A? I think you understand this problem perfectly well and you are using the right equations. You are simply making typographical mistakes right and left. Get a clean sheet of paper, calm down and take a stress pill and you can do this.
Thread Closed
Thread Tools
Similar Threads for: Simple Calculus Word Problem (using derivatives to anaylze function models)
Thread Forum Replies
Hard Calculus Word Problem Introductory Physics Homework 6
Calculus word problem Calculus & Beyond Homework 1
[SOLVED] Calculus: Derivatives Problem #2 Calculus & Beyond Homework 4
Calculus word problem Calculus & Beyond Homework 6
Calculus word problem... Calculus & Beyond Homework 7
