Thread Closed
Reading of a Voltmeter
Share Thread Thread Tools
Jun22-08, 04:21 PM   #1
The circuit in the attached figure (excuse the terrible drawing, I suck at using the paint feature) all meters are idealized and the batteries have no appreciable internal resistance
a) Find the reading of the voltmeter with the switch S open
b) With the switch closed, find the reading of the voltmeter and the ammeter. Which way does the current flow through the switch?
2. Relevant equations
V = I/R (ohm's law)
[tex]\Sigma[/tex]I = 0 (junction law)
[tex]\Sigma[/tex]V = 0 (loop law)
3. The attempt at a solution
To find the reading of the voltmeter I attempted to find the currents going through the 2 emf's and then using the junction rule to find current at point a (the top) and then using ohm's law with that current and the 75 ohm resistor to find the reading of the voltmeter, with the switch open I treated that segment as if the switch line wasn't there, here's what I got
for loop 1 (with the 25V emf)
25V-I1(100 ohms) = 0
25V = I1(100ohms), I1 = .25A
for loop 2 (with the 15V emf)
15V-I2(75 ohms) = 0
15V = I2(75 ohms), I2 = .20A
junction rule .25A-.20A-I = 0, I = .05A
ohm's law for voltmeter
I = V/R, V = IR -> V = (.05A)(75ohms) = 3.75V
I'm not sure if I did the question correctly, if any one can check it for me I would appreciate it, thank you.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jun22-08, 10:40 PM   #2
Recognitions:
Homework Helper Homework Help
It looks like your attachment is coming through finally, so we can look at the circuit.
With the switch open, there is only one loop containing two batteries in series and two resistors in series. That means there's only one current to solve for in part (a).
The ammeter is on the open branch, so naturally it will read nothing. The voltmeter is measuring the potential "drop" across the 15-V battery and the 75-ohm resistor. So you'll need to find the voltage drop across the resistor, then "add in" the 15 volts from the battery appropriately.
After that, we'll deal with part (b).
Thread Closed
Thread Tools
Similar Threads for: Reading of a Voltmeter
Thread Forum Replies
NASA develops 'mind-reading' [nerve signal reading] system Computing & Technology 12
How does it know the potential difference between the two objects? Classical Physics 8
voltmeter Electrical Engineering 1
Voltmeter help Introductory Physics Homework 3
AC Voltmeter Introductory Physics Homework 4
