Thread Closed
The focal length of a mirror. Help me maybe?
Share Thread Thread Tools
Nov10-08, 05:40 PM   #1
Mastering physics problem 23.76 difficulty rating: two bars=difficult
A 2.0-cm-tall object is placed in front of a mirror. A 1.0-cm-tall upright image is formed behind the mirror, 180cm from the object.
What is the focal length of the mirror?
2. Relevant equations
hi / di = ho / do
Thin lens equation
1/o + 1/i = 1/f
3. The attempt at a solution
I made a previous attempt but I know why that was wrong. However, if I can see that the object is 2.0cm high and then its image is 1.0cm high. Does that imply that the distance of the object to the mirror is 180cm times 2 = 360cm so its image is 540cm from the mirror. I understand I can use the height ratio to find the magnification. I just cannot see how I can find the obj distance or image distance. I still have 1/o + 1/i = 1/f and it is impossible to solve this equation when I still have three unkowns.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov11-08, 03:15 AM   #2
Hey
check this:
ok so you focal distance is going to be 160cm
because we can say that the 180=3x
and the ratio between the sizes of the two objects is 2:1
Nov11-08, 01:02 PM   #3
Wow, thanks for the figure. My online homework still said that the answer of 160cm was still the wrong answer. I believe it is because we need to consider the thin lens equation after finding the obj and img distance. I cannot see how you are getting the focal length to be 160cm? I'd be happy if you would just be able to help me get the object distance or image distance to the mirror. I'm not sure if I can see why you set 180cm=3x. Is that because of the three unknowns? That is the wrong way to go about doing it if so.
Dec9-09, 07:45 PM   #4
ok, answer is 40cm.
x=dist from mirror to obj.
x'=dist from mirror to image.
m=magnification
L=vergence before reflection
L'=vergence after reflection
F=power of the mirror
y=object height
y'=image height
f=primary focal point
F=-1/f or f=-1/F
F+L=L'
m=y'/y & x'/x
L=1/x
L'=1/x'
abs(x)+abs(x')=180cm
y'/y=1/2=m=x'/x
so, x'/x = 1/2
abs(x)=abs (2x') (substitution from equation above)
abs(2x')+abs(x')=180cm
abs(3x')=180cm
abs(x')=60cm
so...abs(x)=120cm (180-60)
ok the problem said image was on opposite side of the mirror from the obj, so that would make x' a negative number. In mirrors, real images are on the same side of the object. In this case the image is virtual.
so...
x=120cm
x'=-60cm
L=1/1.2m=.83333 D (diopters)
L'=1/-.6m=-1.66666 D
F=-2.5 D (L'-L)
f=-1/-2.5=.4m or 40 cm
fun problem!
B. Woolverton, O.D. to be
Sep22-10, 03:52 PM   #5
40cm isn't right either, unfortunately. And I don't have the answer just yet! Hopefully, I'll have a solution by tomorrow!
Sep23-10, 12:47 AM   #6
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
An upward image means that the image is virtual. If it is a concave mirror, the virtual image is bigger than the object. So the mirror in the problem is convex. Therefore the focal length is negative, the image distance is negative. |i|+o=180, |i|/o=0.5, that is o=120 and i=-60. Plug in to the lens/mirror equation.
ehild
Thread Closed
Tags
focal length, image, lens, mirror, optics
Thread Tools
Similar Threads for: The focal length of a mirror. Help me maybe?
Thread Forum Replies
Focal Length General Physics 1
Focal length: cm-1? Introductory Physics Homework 4
Focal length of a concave mirror. Introductory Physics Homework 0
focal length Introductory Physics Homework 0
