Torque with an arm holding a weight
The discussion focuses on calculating the forces acting on a forearm holding a 169 N ball, specifically the flexor muscle force (M) and the force at the elbow joint. The flexor muscle force was determined to be 1152 N, while the force applied by the upper arm bone at the elbow joint was calculated to be 3503.23 N. The calculations utilized torque principles, with the end of the arm considered as the pivot point for torque analysis.
  • Understanding of torque and equilibrium in physics
  • Knowledge of force vectors and their components
  • Familiarity with muscle mechanics and biomechanics
  • Ability to perform calculations involving moments and distances
  • Study the principles of torque in static equilibrium
  • Learn about the biomechanics of muscle forces and joint reactions
  • Explore advanced topics in physics related to lever systems
  • Investigate the role of center of gravity in force calculations
Students and professionals in physics, biomechanics, and physical therapy who are interested in understanding the mechanics of human movement and force analysis.
wallace13
A man holds a 169 N ball in his hand, with the forearm horizontal (see the drawing). He can support the ball in this position because of the flexor muscle force M, which is applied perpendicular to the forearm. The forearm weighs 21.4 N and has a center of gravity as indicated.
(a) Find the magnitude of M.
(b) Find the magnitude and direction of the force applied by the upper arm bone to the forearm at the elbow joint.
(Wmuscle*.051)-(21.4*(.089+.051))-(169*.33)= 0
Wmuscle=1152
I got part A correct, but I cannot get part B. I know that The end of the arm (where the ball is) should now be considered the pivot (zero) point.
Here is my attempt:
-(21.4* (.330-.089-.051))+1152- (W elbow*.330)
W elbow= 3503.23N
Wmuscle=1152
Here is my attempt:
-(21.4* (.330-.089-.051))+1152 (you forget to multiply 1152 by the distance to the ball)[/color] - (W elbow*.330)
W elbow= 3503.23N
Alternatively, or as a check, you should just sum all vertical forces to be sure they add to zero.
9K
