Linear Algebra - Diagonalizable and Eigenvalue Proof
In summary, if a diagonalizable n by n matrix A has an eigenvalue lambda with multiplicity n, then A is equal to lambda times the identity matrix. This can be shown by using the fact that A is diagonalizable and rewriting the given assumption in terms of the diagonal matrix D.
B_Phoenix
"Let A be a diagonalizable n by n matrix. Show that if the multiplicity of an eigenvalue lambda is n, then A = lambda i"
I had no idea where to start.
Since [tex] A [/tex] is diagonalizable, we can choose some invertible matrix [tex] S [/tex] such that [tex] A = S D S^{-1} [/tex], where [tex] D [/tex] is diagonal and the diagonal entries of [tex] D [/tex] are the eigenvalues of [tex] A [/tex]. We can translate the assumption regarding the multiplicity of [tex] \lambda [/tex] into a statement about [tex] D [/tex], after which the result follows by using [tex] A = S D S^{-1} [/tex].
What is diagonalization in linear algebra?
Diagonalization is a process in linear algebra where a square matrix is transformed into a diagonal matrix by finding a new basis for the vector space.
How do you check if a matrix is diagonalizable?
A matrix is diagonalizable if it has n distinct eigenvalues (where n is the number of rows/columns) and the corresponding eigenvectors form a basis for the vector space.
What is the significance of eigenvalues and eigenvectors in diagonalization?
Eigenvalues and eigenvectors are important in diagonalization as they allow us to find a new basis for the vector space where the matrix is represented by a diagonal matrix. This can make calculations and solving systems of equations much simpler.
Can a non-square matrix be diagonalizable?
No, a non-square matrix cannot be diagonalizable as diagonalization is only applicable to square matrices.
Is diagonalization the only way to solve systems of linear equations?
No, diagonalization is not the only way to solve systems of linear equations. Other methods such as Gaussian elimination and Cramer's rule can also be used.
  • Math Proof Training and Practice
