| Thread Closed |
Limit of hyperbolic cosine(1/x) |
Share Thread | Thread Tools |
| Aug23-09, 10:26 AM | #1 |
Limit of x2cosh(1/x) as x approaches 0 2. Relevant equations 3. The attempt at a solution I did some algebra,made into the form infinity over infinity and used hopital's rule. I got limit x2e^(1/x). Then I again made into the form infinity over infinity(by making it 1/x2). Then used hopital's rule again and ended up getting limit of e^(1/x) as x approaches 0. Can I assume that it is infinity? But when I draw the graph of e^(1/x),using my graphic calculator, it shows the right and left limits are different and therefore the limit does not exist. Sorry for not showing my steps as I cannot find the limit and other symbols on latex.Thank you for reading! |
| Aug23-09, 11:11 AM | #2 |
[tex]\lim_{u\rightarrow \infty}\frac{e^u}{u^2}[/tex] Now using L'Hopital's rule (twice) will give you the answer more simply. |
| Aug23-09, 11:35 AM | #3 |
Oh okay thank you.Btw Can you please explain to me why when the graph is drawn, there doesn't seem to be a limit as the right and left hand limits are different? Thanks again.
| Aug23-09, 11:41 AM | #4 |
Recognitions:
It is an even function therefore it is symmetric with respect to the y-axis. If what you say is true then the function would not be symmetric with respect to the y-axis hence not even. Perhaps you're plotting your function in a weird interval or are plotting the wrong function?
| Aug23-09, 11:50 AM | #5 |
| Aug23-09, 12:06 PM | #6 |
Recognitions:
Ah I missed that part. However using HallsofIvy's approach you won't have to deal with that limit. Instead you deal with the limit [itex]\lim_{u \to \infty} \frac{e^u}{u^2}[/itex], which is defined. Alternatively you could use the Taylor expansion of the cosh function to see that it diverges.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Limit of hyperbolic cosine(1/x)
| Hyperbolic cosine | Calculus & Beyond Homework | 5 | ||
| Law of cosine | Precalculus Mathematics Homework | 4 | ||
| Cosine | Calculus | 20 | ||
| Cosine Law | Introductory Physics Homework | 3 | ||
| limit of cosine | Calculus | 0 | ||
