Thread Closed
Dynamics Question using nonconstant acceleration
Share Thread Thread Tools
Feb19-10, 09:52 AM   #1
A particle has an initial speed of 27 m/s. If it experiences a deceleration of a = -(6t) m/s^2, where t is in seconds, determine the distance traveled before it stops.
2. Relevant equations
a = dv/dt
v = ds/dt
ads = vdv (not independent from the above two equations)
3. The attempt at a solution
What I know: v(0) = initial speed = 27 m/s
v = final speed = 0 m/s
t(0) = initial time = 0 seconds (assumption)
s(0) = initial displacement = 0 meters (assumption)
I used a = dv/dt and integrated to find the time for the particle to stop. I found it this way:
a = dv/dt = (-6t). dv = (-6t)dt. Lower limit for v(0) = 27, upper limit for v = 0. Lower limit for t(0) = 0, upper limit for t = t. Integrating dv = (-6t)dt, I get -v(0) = -3t^2 --> t = 3 seconds. This is the time it takes the particle to stop.
However it asks for the distance to stop, and I have no idea how to get it. I know I can't use constant acceleration formulas because the acceleration is a function of time. I tried using ads = vdv as that is independent of time, but the acceleration a is dependent on time as a = (-6t) m/s^2
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb19-10, 03:37 PM   #2
In your problem statement you state a constant decelaration of 6 m/s^2
Then you go on with: a = dv/dt = (-6t), which is the correct defintion
Integration produces : v = -3*t^2+v0. You got the integration idea very right.
t = 3 sec.
So, continue with: v = ds/dt in a similar way.
v = ds/dt integration gives: s = (-3/3)*t^3+v0*t+s0
You can solve this for t= 3 sec.
Feb22-10, 05:39 AM   #3
Thanks man.
I'm 're-learning' dynamics for my FIT exam in October. Funny how the simplest solution is right there in front of you and yet, nothing. :)
Feb22-10, 08:55 AM   #4
Why din you try 2nd Order Differential Equation? differentiate twice will induce many unnecessary constants.
Feb22-10, 09:32 AM   #5
Quote by darkdream View Post
Probably could have, but haven't reviewed DEs yet. :)
Thread Closed
Thread Tools
Similar Threads for: Dynamics Question using nonconstant acceleration
Thread Forum Replies
Mechanics/Dynamics, rorational acceleration Introductory Physics Homework 3
Dynamics: Acceleration of a system Introductory Physics Homework 2
Question about Dynamics- force, acceleration Introductory Physics Homework 7
stopping distance with nonconstant deceleration Calculus & Beyond Homework 5
Friction and nonconstant acceleration? Introductory Physics Homework 1
