Thread Closed
Negative acceleration and instantaneous velocity on an object.
Share Thread Thread Tools
Mar9-10, 05:05 PM   #1
The position of an object along a straight tunnel as a function of time is plotted below:
1. Are there any time intervals in which the object has a negative acceleration? If so, list them and explain how you know.
2. Calculate the instantaneous velocity at t=20s and t-45s.
2. Relevant equations
N/A
3. The attempt at a solution
So, for the first question I stated that at 30s to 37s the object's velocity is decreasing, thus the acceleration is negative. However, I was told that this is only part of the interval. What am I missing?
For the second question I did the following calculations:
at 20s = (6 m)/(20s) = 0.3 m/s
at 45s = (16m)/(45s) = 0.36 m/s
I did get the instantaneous velocity at 20s correct but not the instantaneous velocity at 45 s. Where am I going wrong?
Thanks for your assistance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar9-10, 05:34 PM   #2
I would say that the velocity is decreasing from about 27 seconds (at the inflection point) to about 46s (at the other inflection point). Draw tangent lines to the graph, and note the parts where those slopes are getting smaller and smaller (the slope of the slopes).
I think you must be close for the one at 45 seconds. It should be around what you got, I'd say more around .43m/s though it's an estimate when you are using a graph rather than the function.
Mar9-10, 06:16 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by CaptFormal View Post
The velocity is decreasing up until 45 s. Remember that velocity can be negative, so if velocity goes from -1 m/s to -2 m/s, it's decreasing.
The velocity should be negative, not positive. Also, you're calculating average velocity. The question is looking for instantaneous velocity, which is the slope of the tangent of the graph.
Thread Closed
Thread Tools
Similar Threads for: Negative acceleration and instantaneous velocity on an object.
Thread Forum Replies
[SOLVED] Instantaneous Acceleration on a Velocity-Time Graph Introductory Physics Homework 5
the instantaneous velocity of a freely falling object Introductory Physics Homework 3
Finding Instantaneous Acceleration/Velocity Introductory Physics Homework 5
velocity time graph &instantaneous acceleration Introductory Physics Homework 4
Instantaneous velocity and acceleration Introductory Physics Homework 21
