| Thread Closed |
Prime congruence series formula |
Share Thread | Thread Tools |
| Jun17-10, 03:34 PM | #1 |
I'm trying to help a friend solve a problem but as I've never studied number theory, I'm having a bit of trouble myself figuring out how to do it.
We need to find the sum of 1[tex]^{k}[/tex]+2[tex]^{k}[/tex]+...+(p-1)[tex]^{k}[/tex] (mod p), where p is prime. By writing a program that created a table from test cases 2[tex]\leq[/tex]p[tex]\leq[/tex]47 and 1[tex]\leq[/tex]k[tex]\leq[/tex]100, I've conjectured that if p-1 divides k, the sum is p-1 mod p, and if p-1 does not divide k, the sum is 0 mod p. I need to be able to prove this but am not sure how. For the first case, if 1[tex]\leq[/tex]a[tex]\leq[/tex]p-1, then a[tex]^{k}[/tex]=(a[tex]^{p-1}[/tex])[tex]^{n}[/tex] for some n, which is congruent to 1[tex]^{n}[/tex] by Fermat's little theorem, so then it is congruent to 1. Since there are p-1 such terms congruent to 1, their sum is p-1. Let me know if I've done something incorrectly. As for the second case where p-1 does not divide k, I have no idea how to show that the sum is congruent to 0. Any information is appreciated. |
| Jun18-10, 11:12 AM | #2 |
HTH Petek |
| Jun18-10, 11:39 AM | #3 |
If the values are distinct, then each of 1, 2, ..., p-1 appears once, so their sum is (p[tex]^{2}[/tex]-p)/2. If p = 2, then p - 1 = 1 which divides p, so the first case applies. So, p[tex]\geq[/tex]3. Then, p must be odd, so p-1 is even, and (p-1)/2 is an integer. Therefore, (p[tex]^{2}[/tex]-p)/2 = p(p-1)/2 = p*n for some n. This tell us that the sum is zero mod p.
Okay, that part is easy, but I still don't see how to use the fact that p-1 does not divide k to show that the values of each term are distinct. Thanks for the post, let me know what else I'm missing. |
| Jun18-10, 05:45 PM | #4 |
Suppose that (p - 1) does not divide k. Use the Eucidean algorithm to write
k = q(p - 1) + r where 0 < r < p-1 (r > 0 by hypothesis). Consider n^k. Can you take it from there? |
| Jun18-10, 11:55 PM | #5 |
The problem I have understanding how to do that is...suppose I consider n^k and m^k for distinct m and n. We know that mm[tex]^{k}[/tex] is congruent to m[tex]^{r}[/tex] by using Fermat's little theorem again. I'm trying to show that then m[tex]^{r}[/tex][tex]\neq[/tex]n[tex]^{r}[/tex], correct? But, that's not always the case. Suppose we have p = 29, k = 14, m = 4, n = 16, p - 1 clearly does not divide k, but 4m[tex]^{14}[/tex] is congruent to 16[tex]^{14}[/tex], which are both congruent to 1. What am I missing?
| Jun19-10, 12:04 AM | #6 |
Sorry, I was wrong. Consider p = 5, k = 2. Then 1 ^2 + 2^2 + 3^2 + 4^4 == 0 (mod 5), but the individual summands aren't distinct mod 5.
| Jun19-10, 12:29 AM | #7 |
So any ideas how else I can prove that the sum will be 0 mod p? I appreciate the attempt, it seemed like a good approach to it.
| Jun19-10, 02:28 AM | #8 |
Okay, I have a step in the right direction. If p - 1 does not divide k, use the argument above to show that p is odd and p - 1 is even. So, there are an even number of terms in the sum.
Suppose k is odd. Then, consider a[tex]^{k}[/tex], where a[tex]\leq[/tex](p-1)/2. Consider its additive inverse, (p-a)[tex]^{k}[/tex]. Using the binomial formula, we can show the expanded polynomial is congruent to -a[tex]^{k}[/tex], because k is odd. So, for each of the first (p-1)/2 terms, there is a corresponding term in the second (p-1)/2 terms to cancel it from the sum, leaving a resulting sum of 0. Now, how do I show that the sum is 0 when p - 1 does not divide k, and k is even? If this is the case, again consider a[tex]^{k}[/tex], where a[tex]\leq[/tex](p-1)/2. Since p - 1 does not divide k, k is not congruent to 0. This time, (p-a)[tex]^{k}[/tex] is congruent to a[tex]^{k}[/tex]. So, upon combining like terms, we have the 2*[tex]\sum[/tex]a[tex]^{k}[/tex] for 1[tex]\leq[/tex]a[tex]\leq[/tex](p-1)/2. I don't know if this is helpful or what to do with it. Let me know what to do. |
| Jun19-10, 01:37 PM | #9 |
I think I now have a valid solution for the case p - 1 doesn't divide k:
Let g be a primitive root mod p. That is, g generates the multiplicative subgroup that consists of the non-zero elements of Z/pZ. See this Wikipedia article if you're not familiar with primitive roots. Thus, each of the numbers 1, 2, ..., p-1 is congruent to a power of g, mod p. We can then write [tex]1^{k} + 2^{k} + ... + (p - 1)^{k} \equiv 1^{k} + g^{k} + g^{2k} + ... +g^{(p-2)k} \ (mod\ p)[/tex] The RHS of this equation is a geometric series that equals [tex]\frac{1 - g^{(p-1)k}}{1 - g^{k}}[/tex] where [tex]\frac{1}{1 - g^{k}}[/tex] is the multiplicative inverse of [itex]1 - g^{k}[/itex] in Z/pZ. Such an inverse exists because (p - 1) doesn't divide k, and so [itex]g^{k} \not \equiv 1\ (mod\ p)[/itex]. It's easy to see that [itex]g^{(p-1)k} \equiv 1\ (mod\ p)[/itex] and so the sum is divisible by p, as required. Hope this is correct. Petek |
| Jun19-10, 02:55 PM | #10 |
Thanks, I looked at the article as well as a proof that all primes have at least one primitive root, so now it makes perfect sense. I don't think I would have been able to come up with that on my own without more of a background in number theory, so it's definitely appreciated. I'll explain it to my friend when I see her.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Prime congruence series formula
| Possible convergence of prime series | Linear & Abstract Algebra | 8 | ||
| Prime number formula | General Math | 6 | ||
| A formula of prime numbers for interval (q; (q+1)^2) | Linear & Abstract Algebra | 3 | ||
| A formula of prime numbers for interval (q; (q+1)^2), where q is prime number. | Linear & Abstract Algebra | 0 | ||
| New prime series? | Linear & Abstract Algebra | 38 | ||
