| Thread Closed |
Om amp power supply voltage |
Share Thread |
| Oct9-10, 12:33 PM | #1 |
Hi, i'm trying to understand how to correct when you put Vcc as 10V your max output is like 9.18V. Is there a factor on the data sheet or what? I'm trying to build a bi-state multivibrator to generate a 10V peak value but it's being saturated.
thanks. |
| Oct9-10, 12:41 PM | #2 |
Vout = A(Vp-Vn)
A = open loop gain specified by op amp (usually around x10^5) Vp = non-inverting input Vn = inverting input Vcc is normally around tens of volts. Have you tried increasing it to change the range? Based on the eq above, in the linear range: -Vcc< Vout < -Vcc |
| Oct9-10, 01:03 PM | #3 |
What is your output circuit?
Bob S |
| Oct9-10, 01:06 PM | #4 |
well open loop gain is so big that it'll, ideally saturate at Vcc and -Vcc. but practically it'll saturate at a lower value ( 10V saturate to 9.11V). i want to increase Vcc and -Vcc such that i can compensate for this decrease in output voltage. so in order to saturate at say 10V I need to increase Vcc and -Vcc to a higher number like 10.66V to compensate.
| Oct9-10, 01:07 PM | #5 |
looking for a way to calculate it so i can apply it to different Vcc voltages
| Oct9-10, 01:30 PM | #6 |
Why don't you use a voltage comparator with an npn open collector output with a resistor pullup, or a pnp collector output with the emitter tied to Vcc? What circuit are you using?
Bob S |
| Oct9-10, 01:39 PM | #7 |
i'm limited to resistors, opamps and capacitors. My full circuit it a waveform generator. the bi-state multivibrator output is acting as a square wave generator. and i want a 8vp-p value. but if i put 4V and -4V for Vcc and -Vcc it'll def be saturated and inaccurate.
| Oct9-10, 02:45 PM | #8 |
What you could use is a rail-to-rail-output op amp like the Linear LTC1152 chip in an 8-pin DIP package
http://www.google.com/url?sa=t&sourc...mhjOxOgKsCOx_g You could also use two bipolar transistors; a pnp pullup to Vcc and a npn pulldown to Vee, with their collectors tied together. Bob S |
| Oct9-10, 04:38 PM | #9 |
Mentor
http://focus.ti.com/lit/ds/symlink/tl081a.pdf It is a graph of max. peak output voltage vs. supply voltage, under 10 kΩ load. So for that type of op-amp, you'd need at least ±11.2V supplies to get ±10V out. Also, the specs on p. 7 mention VOM, the max. peak output voltage swing, is at least ±12V and typically ±13.5V for a load of 10 kΩ and ±15V inputs. That being said, could you just try supplying ±12V to your op-amp and see what happens? |
| Oct9-10, 04:45 PM | #10 |
what i've done is put 15V Vcc and the max out on the 741 is about 13V. so that 13V output i'll just shrink the amplitude to get my desired value.
| Thread Closed |
Similar discussions for: Om amp power supply voltage
| Capacitor/Transformer Voltage Rating for a 12V Power Supply? | Electrical Engineering | 9 | ||
| Power supply input discharge voltage | Electrical Engineering | 1 | ||
| Need a negative voltage from a 0-60V power supply | Electrical Engineering | 3 | ||
| Internal voltage and resistance of a power supply | Introductory Physics Homework | 13 | ||
| L.E.Ds producing voltage without power supply except for white light incident on it | General Physics | 35 | ||
