New Reply
Total Power Radiated by Ultra-relativistic Particle
Share Thread Thread Tools
Mar6-11, 07:38 AM   #1
Given the formula for power radiated into a solid angle, evaluate the total power radiated to all angles by an ultra relativistic particle, keeping the leading power of [tex] \gamma [/tex] only.
2. Relevant equations
The power formula:
[tex] \frac{dP'}{d\Omega}=\frac{q^2 \alpha^2}{\pi^2 c}\frac{2\gamma^{10}\theta^2}{(\gamma^2 \theta^2 +1)^5} [/tex]
3. The attempt at a solution
Basically, I can't integrate this:
[tex] P'= \int^{2\pi}_0 \int^\pi_0 \frac{q^2 \alpha^2}{\pi^2 c}\frac{2\gamma^{10}\theta^2}{(\gamma^2 \theta^2 +1)^5} sin(\theta)d\theta d\phi [/tex]
I was thinking that since gamma will be large, you can ignore the 1 on the bottom line, but that doesn't get me anywhere. Possibly I'm just missing how I can use the fact that the question says "keeping only the leading power of gamma", but it's not clear to me at all.
Thanks for any hints.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Mar6-11, 12:00 PM   #2
Recognitions:
Homework Helper Homework Help
how about re-arrange as follows
[tex]
Psingle-quote
= \int^{2\pi}_0 \int^\pi_0 \frac{q^2 \alpha^2}{\pi^2 c}\frac{2\theta^2}{( \theta^2 +\frac{1}{\gamma^2})^5} sin(\theta)d\theta d\phi
[/tex]
then consider a power expansion
Mar6-11, 01:47 PM   #3
So just get
[tex] \theta^{10} + 5\theta^8\frac{1}{\gamma^2} [/tex]
on the bottom line? Is this what it means by only keep the leading power of gamma?
I'm still not sure how to go about integrating this though.
Mar7-11, 09:29 AM   #4
Recognitions:
as gamma, gets large, 1/gamma gets small, so I would try to expand in power series in terms of 1/gamma and only keep the lowest order terms. geometric series may be handy here, though you will need to be careful on how you manipulate theta...
New Reply
Tags
radiated power, relativistic power, ultrarelativistic
Thread Tools
Similar Threads for: Total Power Radiated by Ultra-relativistic Particle
Thread Forum Replies
calculate total power radiated Advanced Physics Homework 0
How much power is radiated by the human body? Advanced Physics Homework 2
Ultra-relativistic gas Atomic, Solid State, Comp. Physics 7
Radiated power, what does this even mean? Introductory Physics Homework 9
Net Power vs. Net Radiated Introductory Physics Homework 1
