New Reply
Volume of pyramid
Share Thread Thread Tools
Mar19-11, 09:49 PM   #1
Volume of pyramid
The volume of a pyramid can be evaluated by using the equation V=1/3*A*h where h is
the height of the pyramid and A is the area of the base of the pyramid. The problem is
to design such a triangular pyramid where the volume is V = 72 cm3 and the height is
h = 12 cm. The base of the pyramid is a rectangular isosceles triangle.
2. Relevant equations
a) Determine the area of the base of the pyramid. Pay attention to the unit of your answer.
b) Draw a picture of the base triangle of the pyramid in a proper scale
3. The attempt at a solution
a)
V=1/3*A*h
A=72/(12/3)=18cm2
b) A = 18 = b*y
b=y
so: 18=2*b => b = 9cm
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar19-11, 11:21 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by chawki View Post
a)
V=1/3*A*h
A=72/(12/3)=18cm2
b) A = 18 = b*y
b=y
Your picture didn't come through, but I'm guessing your formula A = 18 = b*y is wrong. Remember the area of a triangle is (1/2)base * height. And even if it were correct, b = y wouldn't give you 18 = 2b, it would be 18 = b2. Two things to fix.
Mar20-11, 07:56 AM   #3
Recognitions:
Retired Staff Staff Emeritus
Well, I can see your picture and it isn't even of a triangle!
Did you simply misread the problem?
Mar20-11, 08:59 AM   #4
Volume of pyramid
Quote by HallsofIvy View Post
Yes i did my mistake, i thought it's a pyramid with 4 faces..
but then we have the area of a triangle that equal 18m2
18=(b*y)/2
To be able to draw that triangle we need to find the length of just one side (assuming the sides are equal) and the problem is..we don't have that
Mar22-11, 12:00 PM   #5
some please give me a hint
Mar22-11, 12:23 PM   #6
Recognitions:
18=(b*y)/2
You still haven't drawn a picture of your pyramid. When you do I think you will find what you need in my earlier post. (reply #2).
Mar22-11, 02:31 PM   #7
i'm not good in drawing but i have an image of it in my mind..and i can't see how i will find the length of the side of that triangle
Mar22-11, 02:48 PM   #8
Recognitions:
Earlier you had that V = (1/3)Ah and you are given that V = 72 and h = 12.
So A = 3V/h = 3*72/12 = 18.
You had that a long time ago. So the area of your isosceles "rectangular" triangle is 18. I presume you know what isosceles means and I presume that "rectangular" triangle means what is usually called a right triangle. And as I pointed out in post #2, the area of a triangle is (1/2)*base* height. What exactly are you stuck on, given you have all this information?
Mar22-11, 06:02 PM   #9
how you know that the triangle is isosceles ? isn't suppose to be equilateral ?
Mar22-11, 06:54 PM   #10
Recognitions:
Didn't you read your own statement of the problem?
Mar22-11, 07:37 PM   #11
ok i must be blind :/
but still we can't find the dimension of that triangle..it's about the triangle and we need the height of the triangle, not the pyramid
Mar22-11, 11:05 PM   #12
Recognitions:
I asked you before if "rectangular" triangle means right triangle. You didn't answer that, but I assume it does. You have an isosceles right triangle and you know its area is 18. Draw a picture of it. You should be able to figure out its dimensions from the picture.
Mar23-11, 06:42 AM   #13
here it is...
i guess that the base of this triangle = it's height.
Mar23-11, 06:45 AM   #14
Recognitions:
Yes, and taking "s" to be the length of one of the legs, the area of the base is
[tex]\frac{1}{2}s^2= 18[/tex].
Mar23-11, 07:03 AM   #15
ahh ok..now i get it..
s2 = 36
s = 6 cm
and then we find the hypotenuse = approximately 8.5 cm
New Reply
Thread Tools
Similar Threads for: Volume of pyramid
Thread Forum Replies
Volume of inverted pyramid. Introductory Physics Homework 5
Volume of a Frustrum of a Pyramid Calculus & Beyond Homework 3
Why isn't the volume of a pyramid Bh/2? Differential Geometry 4
Volume of the frustum of a pyramid Calculus & Beyond Homework 5
Lateral Area and Volume of a Pyramid Precalculus Mathematics Homework 1
