benny74
- 2
A mass m1 = 5.9 kg rests on a frictionless table. It is connected by a massless and frictionless pulley to a second mass m2 = 2.5 kg that hangs freely.
1)What is the magnitude of the acceleration of block 1?
2)What is the tension in the string?
3)Now the table is tilted at an angle of θ = 75° with respect to the vertical. Find the magnitude of the new acceleration of block 1.
4)At what “critical” angle will the blocks NOT accelerate at all?
[Delayed Feedback]
[Delayed Feedback]
5)Now the angle is decreased past the “critical” angle so the system accelerates in the opposite direction. If θ = 38° find the magnitude of the acceleration.
6)Compare the tension in the string in each of the above cases on the incline:
Tθ at 75° = Tθcritical = Tθ at 38°
Tθ at 75° > Tθcritical > Tθ at 38°
Tθ at 75° < Tθcritical < Tθ at 38°
It looks like you assumed the tension in the string was m2g. However, this cannot be true since it is accelerating down! Try using Newton's Second Law for both masses and then add the equations together (note that BOTH masses have acceleration).
