Why Do Race Cars Heat Their Tires Before a Race?
The discussion revolves around the reasons why race cars heat their tires before a race, exploring both the mechanical and performance aspects involved. Participants touch on the implications for traction, tire pressure, and the materials used in tire construction.
  • Some participants propose that heating tires increases their stickiness, enhancing traction due to the softening of the rubber compounds.
  • Others argue that maintaining a nearly constant tire pressure throughout the race is a primary reason for heating the tires, as temperature affects pressure significantly.
  • A participant mentions the importance of optimal tire pressure adjustments based on weather and track conditions, which are critical for performance.
  • There is a reference to the differences in tire behavior between drag cars and stock cars, highlighting various methods used to prepare tires before racing.
Participants generally agree that heating tires improves performance, but there is disagreement about the primary reason for doing so, with multiple competing views on the importance of stickiness versus tire pressure stability.
Some assumptions about tire materials and their behavior under different temperatures are not fully explored, and the discussion does not resolve the nuances of how different racing conditions might affect tire performance.
Individuals interested in motorsports, automotive engineering, or the physics of materials may find this discussion relevant.
JBeans
Why exactly do race cars have their tires heated before a race?
I think they do it so that they become warm. This enables the rubber to become "sticky" and give better traction. For drag cars, I know that they burn out their tires, and for stock cars, they do zig zags while they are restricted to following the pace car because the race has not started yet, or the race has been paused to clear up a reck.
Indeed. Warm tyres are stickier. It's to do with the softening of the polymers (polyisoprene? anyone?) with temperature, - one of the reasons winter tyres are recommended for cold weather use is not so much to do with grip (although tread patterns are optimised for use in wetter weather) as with the increased friction the different compound gives at lower temperatures.
While they are stickier (and that is part of the reason), the primary reason for heating the tires is to maintain a nearly constant tire pressure from when the tire goes on the car to when it comes off some hundred miles later.
Pit crews have gotten so good at making control adjustments to a racecar that they know down to a quarter or eigth of a psi the optimal pressure for the weather, track conditions, and driving style that will give their driver the best performance from the vehicle. This knowledge would be useless if the pressure changed by a few psi from when the tire was put on, to when it was up to racing temperature (from friction with the track surface).
Note that the same applies for your car. If you look, most commercial tires say something along the lines of "inflate COLD to 35 psi". That's because the tire optimally performs at 38-42 psi which is the pressure that the tire will achieve after the air inside has been heated due to driving.
Believe it or not, NASCAR is not necessarily a redneck sport anymore...
Cheers...
I never knew that, learn something every day on here.
Yeah, now only the renecks watch, LOL. I guess I am a redneck, eh, I can live with that.
Pressure eh, cunning!
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 18 ·
