Virtual displacement and generalised forces
The discussion revolves around the concepts of virtual displacement and generalized forces in the context of work done in mechanics. Participants explore the definitions and implications of virtual work, particularly in relation to generalized coordinates and the use of differentials.
  • One participant expresses confusion regarding the definitions of virtual displacement and work, specifically the transition from virtual work to generalized forces.
  • Another participant challenges the notation used, suggesting that the expression F_{k}=δW/δq_{k} may be incorrect and should use partial derivatives instead.
  • A third participant clarifies that δW represents the work done by all forces for a virtual displacement δq_{k} while keeping other generalized coordinates constant.
  • Some participants argue that the partial derivative is not appropriate in this context, as work depends on forces which may also depend on the generalized coordinates.
  • One participant proposes a relationship that expresses δW/δq_{k} in terms of partial derivatives, although they acknowledge that this formula is not commonly seen and may not be useful.
Participants do not reach a consensus on the correct notation or the implications of the expressions involving virtual work and generalized forces. Multiple competing views on the use of δ versus ∂ notation remain unresolved.
There are limitations regarding the assumptions made about the relationships between work, forces, and generalized coordinates. The discussion highlights the complexity of these concepts and the potential for confusion in their application.
Gregg
I am unsure about the virtual displacement and work definition even after looking through the definition and seeming to understand it. If we have
## \delta W = \displaystyle \sum_{i} \vec{F}_i \cdot \delta \vec{r}_i ##,
I can use,
## \delta \vec{r}_i = \sum_{i} \frac{\partial \vec{r}_i}{\partial q_k} \delta q_k ##,
and get to
## \delta W = \displaystyle \sum_{k}\sum_{i} \vec{F}_i \cdot \frac{\partial \vec{r}_i}{\partial q_k} \delta q_k ##.
So,
##\delta W = \sum_{k} \mathcal{F}_k \delta q_k ##.
Then in the derivation it says that this imples that
##\sum_{i} \vec{F}_i \cdot \frac{\partial \vec{r}_i}{\partial q_k}= \mathcal{F}_k = \frac{ \delta W}{\delta q_k} ##.
I thought that ##\delta W = \sum_{k} \frac{\partial W}{\partial q_k} \delta q_k ## and ## \mathcal{F}_k = \frac{\partial W}{\partial q_k} ##. This seems to imply that:
## \delta W = \sum_{i} \frac{\delta W}{\delta q_k} \delta q_k ##,
so where is the distinction, because I can't work out when to use the deltas or ds?
F[itex]_{k}[/itex]=δW/δq[itex]_{k}[/itex] looks wrong to me. Probably a typo of δ for ∂ in both places. ∂W/∂q[itex]_{k}[/itex] would be the limit of δW/δq[itex]_{k}[/itex] as δq[itex]_{k}[/itex] tends to zero.
Here ##\delta W ## is the work done by all forces for virtual displacement ##\delta q_{k} ## while no change in other generalized coordinates.
Don't forget that W depends on forces too, and the forces may depend on ##q_{k}##. Partial derivative is not correct here then.
The deltas are for virtual work / displacement not small change in ##q_k## etc.
Right, so what is actually implied by ## \frac{\delta W}{\delta q_{k}} ##? If partial derivative is not correct, is there a correct way in terms of the partial derivatices to express this? and is this the formal way to do so with the ##\delta##s?
I'm not sure but in my opinion, since δqk is arbitrary, we can set infinitesimal value to it and write the ratio in terms of partial derivatives:
[itex]\frac{\delta W}{\delta q_{k}} \rightarrow \frac{\partial W}{\partial q_{k}}+\sum_{i}\frac{\partial W}{\partial F_{i}}\frac{\partial F_{i}}{\partial q_{k}}[/itex]
However I have never seem such formula perhaps because it's not useful. We often don't have W as a function readily.
  • · Replies 0 ·
  • · Replies 17 ·
