Exponent value in Arrhenius Equation
The Arrhenius equation, represented as k = A*e^(-Ea/RT), illustrates that as the exponent value of e decreases, the rate constant k increases. This relationship is counter-intuitive since higher exponent values yield larger results in isolation. However, the negative exponent in the equation indicates that a decrease in the exponent correlates with an increase in the rate constant, particularly when considering the activation energy (Ea), gas constant (R), and temperature (T). Understanding the properties of exponents is crucial for grasping this concept.
  • Understanding of the Arrhenius equation
  • Knowledge of activation energy (Ea)
  • Familiarity with gas constant (R) and temperature (T)
  • Basic properties of exponents
  • Study the implications of activation energy on reaction rates
  • Explore the role of temperature in the Arrhenius equation
  • Learn about the pre-exponential factor (A) in chemical kinetics
  • Investigate the mathematical properties of exponents in real numbers
Chemists, chemical engineers, and students studying reaction kinetics will benefit from this discussion, particularly those looking to deepen their understanding of the Arrhenius equation and its implications on reaction rates.
bravoghost
This may be a pretty dumb question, but how is it that as the exponent value of e decreases, the rate k increases? This seems counter-intuitive, and when I enter values for e into my calculator and compare them, the higher exponents (e.g. 50 vs. 20) give higher results.
Chemistry news on Phys.org
The Arrhenius equation is
k = A*e-Ea/RT
where k is the rate constant, A is the pre-exponential factor, Ea is the activation energy, R is the gas constant, and T is the temperature (in Kelvin). What are you changing to get the exponential factor to change?
ETA - Also, don't forget the properties of exponents. For the real numbers a and b , where a ≠ 0, one has a-b = 1/ab.
Hopefully it's becoming a bit more clear with those reminders!
12K
