Calculating Electric Field of a Charged Particle at 1m Distance
The discussion revolves around calculating the electric field produced by a charged particle at a distance of 1 meter. The context involves a charged particle with a specified diameter and the forces acting on it, including a drag force and an electric field.
  • Participants explore the relationship between the charge of the particle and the electric field it generates, questioning the relevance of the particle's diameter and whether it should be treated as a point charge.
Some participants have provided insights on using Coulomb's law to calculate the electric field, while others are clarifying the definitions of variables involved. There is an ongoing exploration of the implications of the particle's size and the correct interpretation of the problem's parameters.
Participants note the lack of clarity regarding the use of the particle's diameter in the calculations and whether it affects the interpretation of the problem. The discussion also highlights the need to distinguish between the radius of the particle and the distance from the particle to the point of interest for the electric field calculation.
Soaring Crane
Suppose that a charged particle of diameter 1.00 micrometer moves with constant speed in an electric field of magnitude 1 x 10^5 Newtons per coulomb while acted upon by a drag force of 7.24 x 10^-11 Newtons. What is the charge q1 on the particle? Ignore the effects of gravity.
Express your answer in coulombs to three significant figures.
q1 = 7.25 x 10^-16 C by F = E*q
If this charged soot particle is now isolated (that is, removed from the electric field described in the previous part), what will be the magnitude of the electric field due to the particle at distance 1.00 meter from the particle?
Now I know this must be incorporated:
E = F/q, where
F = (1/[4pi*epsilon_0])*[k]*[(q1q2)/(r^2)]
But where is the diameter or radius of the particle used? And what is r (1 m?) and q2 (is it the same as q1)?
Thanks again.
First of all, you're looking for the field, not the force, so there is no q2 factor (E=F/q, remember). The particle is probably supposed to be considered as a point particle. That means it has no size, it is just a tiny point of charge. All you need is coulomb's law to get the field. (notice there is no place in the coulomb equation to put the diameter. if the particle did have a diameter, you would have to to an integral to get the force)
But why did the problem include 1 micrometer as the diameter for the charged soot particle? Is this just extra info?
Oh, I didn't see that. Well since they give no more information, you can probably assume it's spherical, which means you can still use coulomb's law on it. I don't know why they gave it. Did you have to calculate the drag force yourself using it? Maybe it was just to throw you off.
No, the drag force is given.
Would one use
E = (1/[4pi*epsilon_0])[(q)/(r^2)]
q = charge (7.25 x 10^-16 C) and r is radius (5 x 10^-7 m)
1/[4pi*epsilon_0] = 8.988 x 10^-9
Plugging everything in formula, I got 26065200 N/C, but this wrong. What did I do incorrectly? Is this even correct??
F_drag = 7.24 x 10^-11 N, so F_E is = to this?
What is E_q?
In the prob, I have to find mag. of electric field E.
So I have to solve for E (N/C) = F/q. How does finding q help?
Soaring Crane said:
Would one use
Yes.
As StatusX explained, r is the distance from the particle (its center) to the point where you want to find the field, not the radius of the particle. So r = 1m.
(Note: Forget my last post---I obviously didn't read the entire question! In fact, I should delete it!)
