What is the resistivity of a copper wire with given dimensions and length?
To calculate the resistance of a 31m long number 12 copper wire with a diameter of 2.053mm, the resistivity of copper is given as 1.72x10^-8 Ohm-m. The resistance can be derived using the formula R = ρ(L/A), where R is resistance, ρ is resistivity, L is length, and A is the cross-sectional area. The cross-sectional area for a circular wire can be calculated using A = π(d/2)². Users are encouraged to refer to resources like Wikipedia for further clarification on electrical resistivity and conductivity. Understanding these calculations is essential for solving related problems effectively.
freddy13
A number 12 copper wire has a diameter of 2.053mm. Calculate the resistance of a 31m long piece of such wire. Use rho=1.72x10-8 Ohm-m for the resistivity of copper.
This is the part that I am unsure of, all of my equations for resistivity do not really have anything along the lines of the given constants, nor can I see where one is derived. If it needs to be derived from something else, please post where you get it from so I can figure it out!
You have a uniform cross section. Look here. http://en.wikipedia.org/wiki/Electrical_resistivity_and_conductivity
